<?xml version="1.0" encoding="UTF-8"?>        <rss version="2.0"
             xmlns:atom="http://www.w3.org/2005/Atom"
             xmlns:dc="http://purl.org/dc/elements/1.1/"
             xmlns:sy="http://purl.org/rss/1.0/modules/syndication/"
             xmlns:admin="http://webns.net/mvcb/"
             xmlns:rdf="http://www.w3.org/1999/02/22-rdf-syntax-ns#"
             xmlns:content="http://purl.org/rss/1.0/modules/content/">
        <channel>
            <title>
									Integrating Callin.io with Zapier for automated follow-ups - Features				            </title>
            <link>https://community.callin.io/community/features/integrating-callin-io-with-zapier-for-automated-follow-ups/</link>
            <description>Callin.io Community Discussion Board</description>
            <language>en-US</language>
            <lastBuildDate>Fri, 09 Oct 2026 14:11:28 +0000</lastBuildDate>
            <generator>wpForo</generator>
            <ttl>60</ttl>
							                    <item>
                        <title>Integrating Callin.io with Zapier for automated follow-ups</title>
                        <link>https://community.callin.io/community/features/integrating-callin-io-with-zapier-for-automated-follow-ups/#post-8102</link>
                        <pubDate>Tue, 02 Sep 2025 08:20:48 +0000</pubDate>
                        <description><![CDATA[One of the best things I discovered after using Callin.io for a while was how easily it connects with Zapier. At first, I only used the AI agent to make calls, but then I realized that the r...]]></description>
                        <content:encoded><![CDATA[<p data-start="334" data-end="629">One of the best things I discovered after using Callin.io for a while was how easily it connects with Zapier. At first, I only used the AI agent to make calls, but then I realized that the real power comes when you automate what happens <em data-start="571" data-end="578">after</em> the call. Here’s how I set it up for follow-ups.</p>
<p data-start="631" data-end="839"><strong data-start="631" data-end="649">1. Why Zapier?</strong><br data-start="649" data-end="652" />Zapier is a simple automation tool that connects Callin.io with thousands of apps. Instead of manually copying lead information or reminders, I use Zapier to create a seamless workflow.</p>
<p data-start="841" data-end="872"><strong data-start="841" data-end="870">2. Example workflow I use</strong></p>
<ul data-start="873" data-end="1212">
<li data-start="873" data-end="913">
<p data-start="875" data-end="913">My Callin.io agent qualifies a lead.</p>
</li>
<li data-start="914" data-end="981">
<p data-start="916" data-end="981">Zapier picks up the call outcome through the Callin.io trigger.</p>
</li>
<li data-start="982" data-end="1212">
<p data-start="984" data-end="1036">If the lead is “interested,” Zapier automatically:</p>
<ul data-start="1039" data-end="1212">
<li data-start="1039" data-end="1097">
<p data-start="1041" data-end="1097">Sends them a follow-up email (via Gmail or Mailchimp).</p>
</li>
<li data-start="1100" data-end="1152">
<p data-start="1102" data-end="1152">Creates a new contact in my CRM (I use HubSpot).</p>
</li>
<li data-start="1155" data-end="1212">
<p data-start="1157" data-end="1212">Sends me a Slack notification so I can react quickly.</p>
</li>
</ul>
</li>
</ul>
<p data-start="1214" data-end="1231"><strong data-start="1214" data-end="1229">3. Benefits</strong></p>
<ul data-start="1232" data-end="1333">
<li data-start="1232" data-end="1262">
<p data-start="1234" data-end="1262">No more manual data entry.</p>
</li>
<li data-start="1263" data-end="1289">
<p data-start="1265" data-end="1289">Faster response times.</p>
</li>
<li data-start="1290" data-end="1333">
<p data-start="1292" data-end="1333">Consistent follow-ups that I can trust.</p>
</li>
</ul>
<p data-start="1335" data-end="1367"><strong data-start="1335" data-end="1365">4. Tips from my experience</strong></p>
<ul data-start="1368" data-end="1606">
<li data-start="1368" data-end="1451">
<p data-start="1370" data-end="1451">Test your Zaps with real leads before going live, to make sure no data is lost.</p>
</li>
<li data-start="1452" data-end="1549">
<p data-start="1454" data-end="1549">Use filters in Zapier (for example, only send an email if the lead said “yes” to scheduling).</p>
</li>
<li data-start="1550" data-end="1606">
<p data-start="1552" data-end="1606">Keep your follow-up messages short and personalized.</p>
</li>
</ul>
<p data-start="1608" data-end="1741">Since setting this up, I feel like my AI agent and Zapier are working together as a 24/7 assistant that never forgets to follow up.</p>]]></content:encoded>
						                            <category domain="https://community.callin.io/community/features/">Features</category>                        <dc:creator>Lechus83</dc:creator>
                        <guid isPermaLink="true">https://community.callin.io/community/features/integrating-callin-io-with-zapier-for-automated-follow-ups/#post-8102</guid>
                    </item>
							        </channel>
        </rss>
