AI Agent Function C...
AI Agent Function Calls
Denys_Yudin
(@denys_yudin)
I'm looking to implement OpenAI Function Calling within callin.io.
callin.io has an OpenAI Functions Agent, but I'm unsure about its usage.
What's the distinction between this and the AI Tool Agent?
How do I define a function?
Posted : 13/03/2025 2:40 pm
ria
 ria
(@ria)
Hi everyone,
We're currently streamlining the usage of our AI Agent. If you're using a recent version of callin.io, you'll notice there's now only one Agent option available. This agent is configured to perform function calling using callin.io nodes as tools.
Posted : 13/03/2025 2:49 pm
Denys_Yudin
(@denys_yudin)
Sorry.
I am not sure what you mean…
You said, set up Agent to do function calling using callin.io nodes as tools.
It means when I connect callin.io nodes with Agent, they will call tools?
What is the difference from AI tools Agent?
Posted : 13/03/2025 3:08 pm
ria
 ria
(@ria)
"Function calling" is a broader concept across the entire AI landscape. Within callin.io, we leverage this principle internally with a more advanced implementation, enabling users to integrate our nodes as tools that can subsequently be invoked by the agent.
I wouldn't be overly concerned with the precise definitions; what's important is your ability to simply
Posted : 13/03/2025 3:34 pm
Martin_Kruusimagi
(@martin_kruusimagi)
Yes, you simply need to click the '+' under tools and add the desired functionality for the agent. Ensure you provide clear descriptions of the tools in their configuration so the agent can understand their purpose. Also, give the agent explicit instructions on what you expect from it.
Posted : 14/03/2025 9:43 am
Posted : 12/06/2025 9:44 am
