Features
1
Posts
1
Users
0
Reactions
113
Views
The concept is:
Develop an official AI integration (e.g., utilizing OpenAI GPT, Anthropic, or similar) that enables:
- Automatic generation of complete workflows from natural language descriptions.
- Suggestion and creation of custom nodes based on user needs.
- Offering this as a premium feature within callin.io (via subscription or credits) or allowing users to easily connect to their preferred AI API.
My use case:
- Productivity: Instead of manually building each node, I can describe my requirement—like “download files from FTP, filter by date, send an email with an attachment”—and receive a ready-to-tweak workflow.
- Accessibility: Users without technical expertise can build automations simply by describing the process in plain English.
- Rapid Prototyping: Quickly set up a proof-of-concept in minutes, then refine the specifics.
- Custom Nodes: For particular situations (e.g., interacting with our internal API), the AI can generate the basic node structure, requiring only parameter adjustments from my end.
How I visualize it functioning:
- A "Generate with AI" button integrated into the Workflow Editor toolbar.
- A modal input with a text field for describing the desired workflow.
- A preview of the generated workflow JSON, with an "Import" option to directly place it onto the canvas.
- A usage dashboard to track consumed AI credits.
- AI provider settings (OpenAI, Azure OpenAI, etc.) accessible within callin.io's Settings panel.
Advantages for the community and for callin.io:
- Increases adoption among users lacking technical backgrounds.
- Establishes a new revenue stream through AI credits.
- Differentiates callin.io with a unique "Workflow as Code—by AI" capability.
I'm keen to hear if others find value in this, have UX suggestions, or are interested in collaborating on such an add-on!
Thanks!
Posted : 16/07/2025 8:58 pm
