Airtable and ILoveP...
Airtable and ILovePDF integration for PDF compression
Lauren1
(@lauren1)
I'm currently working with an Airtable base containing 2000 records, and at least 1000 of these records have attachments that vary in size from 1mb to 100mb. This is, as expected, consuming a significant amount of storage. While we plan to compress attachments before uploading them in the future, individually compressing this many attachments isn't practical.
I'm having trouble determining the correct scenario, trigger, and action to use, as well as how to configure them to leverage callin.io as a connection between Airtable and ILovePDF for the purpose of compressing these documents.
Any assistance would be greatly appreciated!
Posted : 28/09/2023 4:28 am
malikwaqaryounis
(@malikwaqaryounis)
Utilize a webhook to extract data from Airtable. Then, using the Ilovepdf module within callin.io, compress the file. After compression, you have the option to store the compressed file in the same file and row in Airtable, or create a new Airtable base for it.
If you require any assistance, you can visit
Posted : 28/09/2023 6:52 am
CodexSolutions
(@codexsolutions)
Hi, please add another column to your Airtable base. This column should be a dropdown with the value "Done".
In callin.io, begin with the Airtable Search module. Configure it to retrieve records that do not yet have the "Done" value. Once you have these records, proceed with the ILOVEPDF integration. After that, update the specific record's column to "Done". This ensures that the same record won't be pulled in subsequent runs.
It's all set!
Adjust the run limit and schedule your scenario as needed.
Happy Automating!
Feel free to ask if you have any questions!
Posted : 28/09/2023 12:39 pm
Lauren1
(@lauren1)
Can you walk me through what that would look like inside callin.io? I’m stuck!
Thanks,
Lauren
Posted : 28/09/2023 2:18 pm
CodexSolutions
(@codexsolutions)
Yes, I'd be happy to assist!
Let's schedule a call. Thank you.
Posted : 29/09/2023 10:26 am
vendy
(@vendy)
Hello!
:wave:
It's fantastic to witness users collaborating and resolving issues together. The strength of this community is truly remarkable.
:muscle:
I just wanted to gently remind everyone that this community functions as a public resource for all users. Our goal is to share suggestions, insights, and potential solutions with one another. Would you be able to share the outcomes of your call?
:telephone_receiver:
This will allow other users to benefit from your findings and easily find solutions to their own challenges.
Thank you very much, and keep up the excellent work!
:sunflower:
Posted : 02/10/2023 7:27 am
