callin.io Node for ...
callin.io Node for Home Assistant AI Assist
Denis
(@denis)
I just wanted to inquire if it's possible to have a callin.io workflow that can be invoked by Home Assistant AI Assist, similar to how one would interact with an OpenAI API.
Thanks
No error:
Not yet built.
  • callin.io version: 1.71.3
  • Database (default: SQLite): default
  • callin.io EXECUTIONS_PROCESS setting (default: own, main): N/A
  • Operating system: Ubuntu 22.04
Posted : 17/12/2024 2:59 pm
ria
 ria
(@ria)
Hi there!
Anything is possible :wink:
I suggest you just dive in and experiment – that's the fun part of any project. You can search the forum for related topics or check YouTube, as there's a wealth of great content available on callin.io.
You can also explore our workflow template collection to find user implementations for specific nodes:
Posted : 23/12/2024 8:36 am
Denis
(@denis)
Thanks a lot Ria,
I have already created a flow that answers calls from Home Assistant.
HASS > Webhook (OpenAI API like) > AI Agent > Ollama LAN server.
Now I'm working on the domotic actions… in order to create an OpenAI interface that sends actions to my Home Assistant.
I'll be experimenting a lot these days :slight_smile:
Thanks again,
Denis
Posted : 23/12/2024 10:08 am
Posted : 31/12/2024 9:19 am
