Generating Dynamic ...
Generating Dynamic PDFs using PDF Monkey with Airtable Data
Malte_Grintz
(@malte_grintz)
Hello!
I'm looking for assistance debugging my scenario. I've spent hours trying to resolve it with ChatGPT, but none of the suggested solutions have worked.
I'll explain the situation as clearly as possible, and if you can solve it, I'd be happy to hire you for this task.
I generate data using an Airtable search records module, which produces between 5 and 8 bundles. The objective is to create dynamic PDF documents via PDF Monkey using this data. Each bundle contains 7 objects that need to be sent to PDF Monkey.
I have a correctly configured template in PDF Monkey with the necessary HTML code, and I can also provide you with correct test data from PDF Monkey to illustrate the required JSON structure. Everything on the PDF Monkey side is confirmed to be working correctly.
My main challenge is constructing the correct JSON output from the Airtable data, ensuring it functions smoothly and dynamically with the 5 to 8 bundles. I attempted using an Array Aggregator followed by a Create JSON module, but without success. I also tried an Aggregate JSON module, also without success.
Currently, I have an API call to ChatGPT integrated to generate the correct JSON. This works about 80% of the time but isn't 100% reliable. Given that this action will run approximately 40,000 times a month, relying on API calls could become quite expensive.
Therefore, the goal is to generate the correct JSON structure without using a ChatGPT API call and with the fewest modules possible to conserve operations.
If you can help with this, please comment, and I'll get back to you quickly!
Languages: English, German, or French are acceptable!
Posted : 16/02/2025 11:52 pm
Pathfinder_Automate
(@pathfinder_automate)
Hello, welcome to the callin.io community! I'm keen to collaborate with you on this. You can schedule a call Here to go over the project requirements. You can also view my Upwork profile Here.
Posted : 17/02/2025 12:15 am
siliceous.solutions
(@siliceous-solutions)
To provide a brief overview, I have considerable experience in generating aggregated data using callin.io. I've also worked with PDF Monkey previously.
It would be beneficial for us to connect via a video call so I can investigate the specific issue you're encountering.
Please feel free to contact me through my website - Contact Us - Siliceous Solutions - World Class Support or book a complimentary session for the video call here - Increase Productivity with Workflow Automation by Siliceous Solutions, to discuss this further.
Regards,
Pam.
Posted : 17/02/2025 4:53 pm
Malte_Grintz
(@malte_grintz)
Thanks, your website looks good, I booked a call for tomorrow :slight_smile:
Posted : 17/02/2025 5:07 pm
This discussion was automatically closed after 30 days. New responses are no longer permitted.
Posted : 18/03/2025 11:52 pm
