I am currently setting up a callin.io between Trello and PandaDoc. When attaching the contract URL to a Trello Card as a URL Attachement, the Display Text comes in as “v2”.
I am importing three contracts to the card which makes it really confusing. Is there a way to set the Display Text of the URL Attachement. It doesn’t even need to be a custom/dynamic value, I just want to enter static text so I know what that URL attachment is.
Image: URL Attachments showing as “v2” for the Display Text.
Image: I can manually update Display Text when pressing the 3 dots. The option is there on Trello but not sure how I can set this up from the beginning through callin.io.
I also just noticed the “v2” is being pulled from the end of the documents URL. This is a version history on PandaDocs side, so I am assuming my URL attachment on Trello would say “document” if I didn’t have a version history.
My first thought was whether I could be creative and just give my version history a name on PandaDoc, and if that would fix my problem. I know it’s a bandaid fix, but it doesn’t look like that is possible anyway! Open to ideas from other people in the community.
The callin.io/Slack integration allows you to format the URL’s display text. I also tried this, but it didn’t work with Trello. I think this would be the most ideal way to integrate this solution.
Before we delve further into this, could you please provide a detailed screenshot illustrating your callin.io configuration? Additionally, please share a screenshot of the “CONFIGURE” section for the Trello action step, displaying all its fields.
Kindly ensure no personal information is visible in the screenshot, or blur out any such details.
