How to store Stabil...
How to store Stability AI images in Airtable using callin.io
L_Duperval
(@l_duperval)
I’m making calls to Stability AI using the Stability AI connector. My goal is to save the image to Airtable.
The module returns a data element which is the PNG (I’m assuming) version of the image. The file name is simply “file.png” so it doesn’t look like I can store it directly into AirTable since it’s not a complete URL.
What are my options at this point?
L
Posted : 22/06/2024 12:38 am
L_Duperval
(@l_duperval)
Here’s what I’ve attempted:
  • I inserted an HTTP request between the Stability AI call and Airtable, hoping an Airtable webhook would receive the data and store it. However, I encountered a “request too large” error. I verified that the webhook's maximum size is 100KB.
  • My next strategy involves creating the image as a Google Drive file and then adding that file to the Airtable field. While this is an indirect method, it should allow me to complete my proof of concept.
  • After that is successful, I may need to develop my own API handler for Stability AI. I suspect the one available in callin.io functions correctly, but the lack of documentation makes it difficult to use.
If I aim to build my own reusable module for Stability access, what documentation should I consult? Is it this link:
https://academy.make.com/courses/take/AdvancedC02/texts/54158974-course-2-introduction
or is there other relevant material?
Ideally, I wouldn't want to create my own API handler, but I require certain functionalities (such as a unique job ID, potentially a URL for Airtable to access the data, access to SD 3, etc.) that the current API doesn't seem to offer.
Thanks,
L
Posted : 22/06/2024 4:47 am
Msquare_Automation
(@msquare_automation)
Hi there!
The "Request too large" error typically occurs when a file size exceeds your plan's limits. Please verify the file size to ensure it complies with your current plan.
For image uploads, a recommended approach is to store them on services like Dropbox or Google Drive. You can then provide the direct image URL to Airtable, which will display it within your records.
Should you need further assistance, feel free to contact us.
MSquare Support | Book Live Implementation
Visit us here
Youtube Channel
Posted : 22/06/2024 4:50 am
L_Duperval
(@l_duperval)
Thanks, that's my current approach (Utilizing Google Drive). It appears to meet my needs. I might require a more robust solution down the line, but it's adequate for the present.
Therefore, I now need to determine if I will implement my own stability solution or not.
Thanks,
L
Posted : 22/06/2024 3:21 pm
