Integrating Calendl...
Integrating Calendly appointments with Airtable using callin.io
Jacob
(@jacob)
3 Step callin.io
Step 1. Invitee created in Calendly
Step 2. Find record in Airtable (cross referencing email)
Step 3. Update record in Airtable with appointment start time in the appointment time column on Airtable..
First 2 steps completed without errors, testing and reviewing step 3 and... failure..
With this error
We encountered an issue sending your test.
The app responded with "NOT_FOUND". This typically occurs when a field value used in this step is missing, or we cannot locate specific information within your connected app or service. Please verify that the information exists and that the field values utilized in this step are entered accurately. We sent a request to api.airtable.com and received a (404) Not Found response.Learn how to fix
AndrewJDavison_Luhhu
(@andrewjdavison_luhhu)
Could you please share a screenshot of your setup for step 3?
Posted : 04/04/2020 12:00 am
Jacob
(@jacob)
Yes, here it is!
Posted : 05/04/2020 12:00 am
So, in the “Record” field, instead of mapping the ‘Email’ field, you need to map the ‘ID’ field from step 2.
