Integrating callin....
Integrating callin.io with RingCentral
Charlie_P
(@charlie_p)
Hello! I'm encountering an issue where my callin.io assistant isn't responding to incoming calls from RingCentral. I've attempted to configure it using an API call, but it doesn't seem to be capturing any calls. Any help would be appreciated!
Posted : 25/02/2025 2:59 pm
To allow others to assist you with your scenario, please provide the following:
Relevant Screenshots
Please share screenshots of your scenario, any error messages, relevant module fields, and relevant filter settings. It would really help other community members to see what you’re looking at.
Scenario Blueprint
Please export the scenario blueprint file to allow others to view the mapped variables in the module fields. At the bottom of the scenario editor, you can click on the three dots to find the Export Blueprint menu item.
Output Bundles of Modules
Please provide the output bundles of the modules by running the scenario (or get from the scenario History tab), then click the white speech bubble on the top-right of each module and select “Download input/output bundles”.
A. Upload as Text File
Save each bundle contents in your text editor as a bundle.txt file, and upload it here into this discussion thread.
If you are unable to upload files on this forum, alternatively you can paste the formatted bundles.
These are the two ways to format text so that it won’t be modified by the forum:
    content goes here
Providing the input/output bundles will allow others to replicate what is going on in the scenario even if they do not use the external service.
By providing these details, it will allow others to assist you better.
Posted : 25/02/2025 3:02 pm
