Request to increase...
Request to increase timeout limit for AI modules from 40 to 120 seconds
Justin_Duveen
(@justin_duveen)
Hello, I'm working with a sophisticated multi-agent system that utilizes both Perplexity and Claude. I'm encountering intermittent Time-out errors from both AI modules. I've incorporated delays into my workflow to reduce the frequency of calls, but it appears that the complexity of the prompts causes the LLMs to exceed the 40-second response limit. Could you please extend the Time-out limit for AI modules from 40 seconds to 120 seconds?
I suspect other AI developers face this same frustrating issue. It creates significant stress when preparing for production, and building robust error handling into a 15-step AI agent framework is quite challenging.
Thank you for your assistance and for developing a fantastic system!!
Posted : 02/10/2024 6:44 pm
That’s an excellent suggestion! I’m confident many users would find this a valuable feature.
You can submit this idea on the Idea Exchange, under App improvement ideas
Remember to search first to ensure it hasn't already been suggested, preventing duplicate entries.
Screenshot_2024-01-17_130153
I hope this is helpful! Please let me know if you have any more questions or encounter any issues.
P.S.: Investing some time in the callin.io Academy can significantly reduce the time and frustration you might experience using callin.io.
Posted : 03/10/2024 12:31 pm
Justin_Duveen
(@justin_duveen)
Thanks. Have incorporated it as you recommended.
Posted : 04/10/2024 10:51 am
Justin_Duveen
(@justin_duveen)
Hi, any updates on this?
Posted : 14/10/2024 2:29 pm
Follow your suggested feature for any updates.
Posted : 15/10/2024 5:59 am
