Review: Vector Stor...
Review: Vector Store Tool (+ Langchain Code Alternative!)
6 Users
Jim_Le
(@jim_le)
In version 1.49, callin.io finally included the Vector Store Tool as part of the officially supported tools for AI Agent nodes. Hurrah!
I spent a few hours familiarising myself with the tool and wanted to share some thoughts on how I’d use it going forward.
Note:
These views are my totally my own. I enjoy talking about callin.io and AI and if you do too, check out my other posts in the forum!
What is the Vector Store Tool?
As with other callin.io’s AI agent tools, the Vector Store Tool extends the knowledge fetching capabilities of your agents and offers a new standard for connecting to your vector store of choice without the additional complexity of introducing sub-workflows.
To start using this tool,
  • Find it in the “tools” options for your AI agent.
  • Connect your vector store and to that, connect your embedding model.
  • Connect an additional language model (LLM) to the vector store.
How it works
The Vector Store Tool performs very much like the Vector Store Retriever but a key difference is that rather than returning raw results, the tool uses an additional LLM to return an “answer” to the agent’s query.
Pros
  • For most knowledge retrieval use-cases, this works great and introduces what is effectively a multi-agent workflow by having two LLMs talk to each other.
  • Very easy to understand and put together - as mentioned previously, no need for a sub-workflow tool to use the vector store nodes. Great choice by the callin.io team with UI choices to keep these tools similar to their original counterparts.
Cons
  • In my particular use-case - which I acknowledge may not be how others typically use vector stores - I noticed that prompt instructions from the root agent may not be fully transferred to the tool’s LLM prompt, which may miss some key details you wanted to pick out from the retrieved information.
  • Additionally, if you use the metadata as part of the response and not only for filtering, then you may lose this information in the tool’s LLM response as well.
  • It’s not possible to modify the generic prompt instructions of the tool’s LLM. This means a lack of post-retrieval processing before sending the tool’s response and possibly a fix for the above.
Verdict: Nice!
A great addition to the AI agent’s arsenal and looking forward to more!
:white_check_mark:
Should now be the standard way AI Agents (with tools) get access to vector store resources.
:white_check_mark:
Suitable for a majority of vector store retrieval use-cases without additional modification.
:warning:
It may be difficult to get exact wording/extracts from retrieved documents as the result is “summarised” twice (tool’s LLM > agent’s LLM).
:warning:
If you use vector store metadata for more than just filtering, you may have trouble getting this data into the response.
Ok, Let’s Go Custom Langchain Code!
So, obviously with hitting the above limitations, I had to investigate how to go about overwriting the tool’s LLM prompt. The scenario is for my recipe library in my Qdrant Vectorstore where I store the recipe ID, categories and URL in the metadata and would like to pull these back out in the tool’s response. Here’s what I came up with…
1. Build your own Vector Store Tool to Override Tool’s LLM Prompt
After trying a few things, the only way I found to do this was to use a custom Langchain Code Node implementation:
  • A “supply data” sub-node using Langchain Code node which replicates the vector tool node shape, basically one-to-one.
  • Inside, it uses a createRetrievalChain which connects to the vector store and LLM.
  • Since we’re building the entire chain from scratch, we can now override the system prompt with SystemMessagePromptTemplate.
  • Finally, returning our chain’s “invoke” wrapped in a DynamicTool allows this to be used by our Agent. Don’t forget to set the name and description!
So we kinda just rebuilt the Vector Stool Tool but this worked pretty well in my opinion. By customising the tool’s prompt, I could get the recipe attributes I needed.
:white_check_mark:
More control over tool response to surface information that is needed.
:x:
Agent and tool prompts need to be aligned. More risk of breaking due to upgrades.
### 2. Build your own Vector Store Tool Without LLM
After implementing the above, it got me thinking if the tool really needed the LLM in my scenario. So I tried an alternative implementation without the LLM and instead with the tool returns the vector store documents directly.
* Similar to the above implementation but does not use the __createRetrievalChain__ and so no need for the LLM.
* The tool simply performs a `` similaritySearch() `` and returns them as the tool’s response.
* Wrapped in __DynamicTool__ as before.
After testing, the response were much more detailed for my particular use-case. Additionally, I also found possibility for post-retrieval processing which may help if you’re worried about token count.
:white_check_mark:
Keep all prompts in one place for easier maintenance.
:x:
Higher token count for agent.
<n8n-demo frame="true" workflow="%7B%22meta%22%3A%7B%22instanceId%22%3A%2226ba763460b97c249b82942b23b6384876dfeb9327513332e743c5f6219c2b8e%22%7D%2C%22nodes%22%3A%5B%7B%22parameters%22%3A%7B%7D%2C%22id%22%3A%221d5af350-b5b6-44d5-a044-96feb81c48c7%22%2C%22name%22%3A%22When%20chat%20message%20received%22%2C%22type%22%3A%22%40n8n%2Fn8n-nodes-langchain.chatTrigger%22%2C%22typeVersion%22%3A1%2C%22position%22%3A%5B3100%2C220%5D%2C%22webhookId%22%3A%2297ca38dd-0634-4c18-a5ad-de5362550285%22%7D%2C%7B%22parameters%22%3A%7B%22options%22%3A%7B%7D%7D%2C%22id%22%3A%229fc7b22f-8efa-4cfd-becb-a6a104054476%22%2C%22name%22%3A%22OpenAI%20Chat%20Model5%22%2C%22type%22%3A%22%40n8n%2Fn8n-nodes-langchain.lmChatOpenAi%22%2C%22typeVersion%22%3A1%2C%22position%22%3A%5B3260%2C400%5D%2C%22credentials%22%3A%7B%22openAiApi%22%3A%7B%22id%22%3A%228gccIjcuf3gvaoEr%22%2C%22name%22%3A%22OpenAi%20account%22%7D%7D%7D%2C%7B%22parameters%22%3A%7B%22qdrantCollection%22%3A%7B%22_rl%22%3Atrue%2C%22value%22%3A%22hellofresh%22%2C%22mode%22%3A%22list%22%2C%22cachedResultName%22%3A%22hellofresh%22%7D%7D%2C%22id%22%3A%22bd7e3cb6-a709-4a37-a4b3-f53c1f71feef%22%2C%22name%22%3A%22Qdrant%20Vector%20Store3%22%2C%22type%22%3A%22%40n8n%2Fn8n-nodes-langchain.vectorStoreQdrant%22%2C%22typeVersion%22%3A1%2C%22position%22%3A%5B3400%2C520%5D%2C%22credentials%22%3A%7B%22qdrantApi%22%3A%7B%22id%22%3A%22NyinAS3Pgfik66w5%22%2C%22name%22%3A%22QdrantApi%20account%22%7D%7D%7D%2C%7B%22parameters%22%3A%7B%22options%22%3A%7B%7D%7D%2C%22id%22%3A%227949d78c-8652-4023-9bdf-bd61790e7e04%22%2C%22name%22%3A%22Embeddings%20Mistral%20Cloud3%22%2C%22type%22%3A%22%40n8n%2Fn8n-nodes-langchain.embeddingsMistralCloud%22%2C%22typeVersion%22%3A1%2C%22position%22%3A%5B3400%2C640%5D%2C%22credentials%22%3A%7B%22mistralCloudApi%22%3A%7B%22id%22%3A%22EIl2QxhXAS9Hkg37%22%2C%22name%22%3A%22Mistral%20Cloud%20account%22%7D%7D%7D%2C%7B%22parameters%22%3A%7B%22options%22%3A%7B%7D%7D%2C%22id%22%3A%223b8427f8-67d4-4abb-9ed7-0383fe3016da%22%2C%22name%22%3A%22Using%20Non-Chain%20Vector%20Store%20Tool%22%2C%22type%22%3A%22%40n8n%2Fn8n-nodes-langchain.agent%22%2C%22typeVersion%22%3A1.6%2C%22position%22%3A%5B3280%2C220%5D%7D%2C%7B%22parameters%22%3A%7B%22content%22%3A%22%23%23%23%23%20Custom%20Vector%20Store%20Tool%20Without%20LLM%5Cn*%20Returns%20raw%20results%20from%20vector%20store%5Cn*%20Allows%20for%20post-retrieval%20processing%22%2C%22height%22%3A90.02385576335456%2C%22width%22%3A364.24916154317975%7D%2C%22id%22%3A%222dff3005-400b-4101-bf65-de09846993b6%22%2C%22name%22%3A%22Sticky%20Note2%22%2C%22type%22%3A%22n8n-nodes-base.stickyNote%22%2C%22typeVersion%22%3A1%2C%22position%22%3A%5B3100%2C100%5D%7D%2C%7B%22parameters%22%3A%7B%22code%22%3A%7B%22supplyData%22%3A%7B%22code%22%3A%22const%20%7B%20DynamicTool%20%7D%20%3D%20require(%5C%22%40langchain%2Fcore%2Ftools%5C%22)%3B%5Cn%5Cnconst%20name%20%3D%20%27searchrecipes%27%3B%5Cnconst%20description%20%3D%20%27Use%20this%20tool%20to%20search%20for%20recipes%27%3B%5Cnconst%20topK%20%3D%204%3B%5Cnconst%20filters%20%3D%20%7B%7D%3B%5Cn%5Cnconst%20vectorStore%20%3D%20await%20this.getInputConnectionData(%27aivectorStore%27%2C%200)%3B%5Cn%5Cnconst%20vectorStoreTool%20%3D%20new%20DynamicTool(%7B%5Cn%20%20name%2C%5Cn%20%20description%2C%5Cn%20%20func%3A%20async%20(input)%20%3D%3E%20%7B%5Cn%20%20%20%20const%20res%20%3D%20await%20vectorStore.similaritySearch(input%2C%20topK%2C%20filters)%3B%5Cn%20%20%20%20return%20JSON.stringify(res)%3B%5Cn%20%20%7D%5Cn%7D)%3B%5Cn%5Cnreturn%20vectorStoreTool%3B%22%7D%7D%2C%22inputs%22%3A%7B%22input%22%3A%5B%7B%22type%22%3A%22aivectorStore%22%2C%22maxConnections%22%3A1%2C%22required%22%3Atrue%7D%5D%7D%2C%22outputs%22%3A%7B%22output%22%3A%5B%7B%22type%22%3A%22aitool%22%7D%5D%7D%7D%2C%22id%22%3A%223c4670cb-0b5f-4df8-a32b-6a6bbff68026%22%2C%22name%22%3A%22Vector%20Store%20Without%20Chain%22%2C%22type%22%3A%22%40n8n%2Fn8n-nodes-langchain.code%22%2C%22typeVersion%22%3A1%2C%22position%22%3A%5B3400%2C400%5D%7D%5D%2C%22connections%22%3A%7B%22When%20chat%20message%20received%22%3A%7B%22main%22%3A%5B%5B%7B%22node%22%3A%22Using%20Non-Chain%20Vector%20Store%20Tool%22%2C%22type%22%3A%22main%22%2C%22index%22%3A0%7D%5D%5D%7D%2C%22OpenAI%20Chat%20Model5%22%3A%7B%22ailanguageModel%22%3A%5B%5B%7B%22node%22%3A%22Using%20Non-Chain%20Vector%20Store%20Tool%22%2C%22type%22%3A%22ailanguageModel%22%2C%22index%22%3A0%7D%5D%5D%7D%2C%22Qdrant%20Vector%20Store3%22%3A%7B%22aivectorStore%22%3A%5B%5B%7B%22node%22%3A%22Vector%20Store%20Without%20Chain%22%2C%22type%22%3A%22aivectorStore%22%2C%22index%22%3A0%7D%5D%5D%7D%2C%22Embeddings%20Mistral%20Cloud3%22%3A%7B%22aiembedding%22%3A%5B%5B%7B%22node%22%3A%22Qdrant%20Vector%20Store3%22%2C%22type%22%3A%22aiembedding%22%2C%22index%22%3A0%7D%5D%5D%7D%2C%22Vector%20Store%20Without%20Chain%22%3A%7B%22aitool%22%3A%5B%5B%7B%22node%22%3A%22Using%20Non-Chain%20Vector%20Store%20Tool%22%2C%22type%22%3A%22ai_tool%22%2C%22index%22%3A0%7D%5D%5D%7D%7D%2C%22pinData%22%3A%7B%7D%7D">
Conclusion
I think both custom implementations are equally fine depending on certain use-cases but I found in mine, the extra LLM summary/answer was redundant and I’d prefer to just return the actual documents to the agent. If the new vector store tool isn’t doing for you, definitely give these a try!
Thanks!
Jim
If you enjoy posts on callin.io and AI, check out my other posts in the forum!
Follow me on LinkedIn or Twitter/X.
Posted : 15/07/2024 11:52 am
miko
 miko
(@miko)
Hello, is it possible that the search filter on the Qdrant vector store (retrieve) won't work when connected to "Vector Store Without Chain"?
Posted : 02/08/2024 5:01 pm
Jim_Le
(@jim_le)
Yes, you will need to update to release 1.50.0 or later, as the search filter option was introduced in the Qdrant vector store node.
Posted : 02/08/2024 5:43 pm
miko
 miko
(@miko)
Yes, I have it, but the filter isn't functioning when connected to that Langchain code.
Posted : 02/08/2024 6:00 pm
Jim_Le
(@jim_le)
Interesting… I tested again with all 3 examples in this post and it does seem to be working for me at least. Perhaps you’ve uncovered a bug?
If you are able to share your workflow and maybe some sample data (e.g., how are you defining metadata?), that would be very helpful!
Posted : 03/08/2024 9:04 am
miko
 miko
(@miko)
Hi, I've just added metadata to a collection in Qdrant and am using a filter like this:
"should": [
"key": "metadata.CaseID",
"match": {
"text": "SOMETHING1"
"match": {
"text": "SOMETHING2"
When the Qdrant Vector Store node is connected to the Vector Store Retriever, the filter works correctly. However, if it's connected to the Vector Store Without Chain, it does not.
I have the collection set up with this simple information:
Posted : 04/08/2024 12:31 am
Jim_Le
(@jim_le)
Thanks for the example. This is quite similar to what I used for testing, so I'm not entirely sure why our outcomes differ.
Based on what you shared, I suspect that match only accepts value, any, and except as child keys (see docs), which might make text invalid.
Could you please try one of these options:
  "should": [
    {"key": "metadata.CaseID", "match": { "value": "SOMETHING1" } },
    {"key": "metadata.CaseID", "match": { "value": "SOMETHING2"} }
or using the any option:
  "must": [
          "match": {
              "any": [ "SOMETHING1", "SOMETHING2" ]
Posted : 04/08/2024 9:31 am
Zotek
(@zotek)
My second build functions flawlessly for my specific needs. However, I'm surprised this isn't included as a node option. Thank you!
Posted : 03/10/2024 2:20 am
Alexandre_Leitao
(@alexandre_leitao)
Sorry but hijacking this lol… Ok… the whole stuff works… but when I get to the vector store (qdrant) I want to use the filter with the project_id that the agent got from another tool.
I’m trying to figure out for myself for 2 days how can I pass something to that filter field but the only thing it sees is the chat node can't see anything the agent node produced… How would you approach that? my workflow is basically like yours chat, agent, one tool to retrieve the project one to go to the vector store that uses a qdrant vector store with open ai embedding and model
Posted : 31/10/2024 10:20 am
Alexandre_Leitao
(@alexandre_leitao)
Found in another topic. I've added an additional agent before the main agent to recover the ID. This involves one more call to the AI API, but it allows me to reference it in the vector store filter.
Posted : 31/10/2024 5:19 pm
Jim_Le
(@jim_le)
This is a known limitation of the Vector Store Tool; you cannot modify this value directly within the agent node. However, it is indeed possible for the agent to utilize values from one tool for its other tools.
Here is a concise template to illustrate the usage with the Langchain Code node:
  • In the chat, prompt with: "I’m looking for a spicy Asian recipe."
  • The agent will employ the cookbook tool to identify available cookbooks and retrieve their corresponding IDs.
  • Subsequently, the agent will utilize the cookbook recipe tool, passing the most suitable cookbook ID along with the user's query.
Posted : 31/10/2024 6:01 pm
genieyuan
(@genieyuan)
Does this mean we can connect to a vector store not currently listed? Many databases now offer their own vector capabilities. I'm trying to understand how I might use that instead of what callin.io provides. Thanks
Posted : 08/12/2024 3:53 pm
Jim_Le
(@jim_le)
Does this imply we can integrate with a vector store not currently listed?
To utilize a vector store not supported by Langchain, yes, it's possible by employing Langchain's DynamicStructuredTool. This requires:
  1. You are using a self-hosted version of callin.io.
  2. You have a method to connect to your vector store using JavaScript (e.g., REST, RPC, GraphQL).
Additionally, if your vector store is supported by Langchain but not yet available in callin.io, consider submitting a Feature Request to the development team.
Posted : 09/12/2024 12:11 pm
genieyuan
(@genieyuan)
Thanks Jim. Yes, the vector store is Couchbase (if you're familiar with it). It's supported by Langchain, but not directly exposed by callin.io. A request has been made. Do you have an estimate on when this might be addressed?
Will the workaround involve using DynamicStructuredTool exclusively?
Posted : 09/12/2024 2:55 pm
Jim_Le
(@jim_le)
Do you know approximately when this will be addressed?
Given the volume of other requests, I don't expect it very soon, but it's good to note that people are asking for this functionality!
Will the workaround involve solely using DynamicStructuredTool?
Yes. I've completed a comparable task for Redis. You can find the tutorial here -Using Redis VectorStore Search in callin.io
Posted : 09/12/2024 3:00 pm
Page 1 / 2
