Transcribing Slack ...
Transcribing Slack Voice Notes using OpenAI
KB-OD
(@kb-od)
Has anyone managed to achieve this, or is this functionality no longer operational?
I'm attempting to transcribe a Slack voice note using the OpenAI module, but the HTTP module doesn't seem to be working, or perhaps I'm configuring it incorrectly? Any guidance would be greatly appreciated!
Posted : 25/02/2025 12:52 pm
Try using the Slack “Download a File” module:
Downloads a file.
For more information, see https://www.make.com/en/integrations/slack and https://www.make.com/en/help/app/slack in the help centre.
Hope this helps! Let me know if there are any further questions or issues.
P.S.: Investing some effort into the callin.io Academy will save you lots of time and frustration using callin.io.
Posted : 25/02/2025 1:40 pm
KB-OD
(@kb-od)
I've tried it, and it's still not functioning correctly.
Apologies, I'm new to using callin.io.
:sweat_smile:
Posted : 26/02/2025 4:23 am
You can't run individual modules without knowing example values for the fields.
Try executing the entire scenario by clicking the "Run Once" button.
Screenshot_2025-02-25_220239
For additional details, please refer to these similar questions that have been previously addressed by other community members:
Hope this assists you! Please let me know if you have any further questions or encounter any issues.
P.S.: Investing some effort into the callin.io Academy will save you considerable time and reduce frustration when using callin.io.
Posted : 26/02/2025 4:42 am
KB-OD
(@kb-od)
Understood. I've tested it, and it's now functioning without any issues. I appreciate your assistance!
Posted : 26/02/2025 4:48 am
No problem, really glad I could help!
  1. If anyone has a new question in the future, please start a new thread. This makes it easier for others with the same problem to search for the answers to specific questions, and you are more likely to receive help since newer questions are monitored closely.
  2. The callin.io Community guidelines encourages users to try to mark helpful replies as solutions to help keep the Community organized.
This marks the topic as solved, so that:
  • others can save time when catching up with the latest activity here, and
  • allows others to quickly jump to the solution if they come across the same problem
To do this, simply click the checkbox at the bottom of the post that answers your question:
Screenshot_2023-10-04_161049
  1. Don’t forget to like and bookmark this topic so you can get back to it easily in future!
Here are some useful links and guides you can use to learn more on how to use the callin.io platform, apps, and app modules. I found these useful when I was learning callin.io, and hope they might benefit you too —
Getting Started
Help Centre Basics
Articles & Videos
Posted : 26/02/2025 4:50 am
