Using callin.io wit...
Using callin.io with Notion templates
Magnusnordic
(@magnusnordic)
Hey,
Can I get callin.io to use a Notion template when I create a new one?
I want it to use a template named “To-do everyday”.
Posted : 25/08/2022 8:51 am
JugaadiTech
(@jugaaditech)
Howdy Welcome to the callin.io Community!
This should directly answer your question!
Templating Workflow callin.io x Notion
Additional Information on Notion
In Notion, it doesn't seem possible to create a new database item with a relation to a different database? - #4 by JugaadiTech
Notion Mentions to Slack messages - #2 by JugaadiTech
https://developers.notion.com/page/notion-platform-roadmap#longer-term
All Notion Threads
Posted : 29/08/2022 5:31 am
Magnusnordic
(@magnusnordic)
Hey,
Do you have a simpler guide on how to create it?
And which API should I be using?
Please provide the rewritten markdown content.
Posted : 29/08/2022 6:19 am
JugaadiTech
(@jugaaditech)
Could you please clearly describe your objective?
Screenshots would be very beneficial.
Kindly provide the rewritten markdown content, ensuring it is in markdown format.
Posted : 29/08/2022 6:25 am
Magnusnordic
(@magnusnordic)
When I reach the "create Fake New User" step, I'm only getting "JSON string" from the JSON transform.
Also, what type of configuration should I use for the last two Notion steps, and which API Pages should I be using?
However, I can see that you might be able to export the blueprint.
Posted : 29/08/2022 12:11 pm
