Using Prompt Cachin...
Using Prompt Caching in callin.io
7 Users
Kiremit
(@kiremit)
Many models support prompt caching, which is highly advantageous for lengthy system prompts, repeated references to the same video, or any other token-intensive operations.
Is it feasible to implement a prompt caching system within callin.io?
  • callin.io version: 1.81.4
  • callin.io EXECUTIONS_PROCESS setting (default: own, main): Own
  • Running callin.io via (Docker, npm, callin.io cloud, desktop app): Google Cloud
  • Operating system: WIndows10
Posted : 07/03/2025 7:35 am
solomon
(@solomon)
When utilizing OpenAI, prompt caching occurs automatically.
Within callin.io, when you set up a prompt, it's transmitted with every execution. There isn't an integrated way to "cache" it independently to conserve tokens.
This is fundamental to how LLM APIs operate: each request requires the complete context (system, user, and assistant messages) to produce a response.
However, OpenAI already manages token savings internally when you submit similar requests repeatedly.
You can find more details in this documentation:
:point_right:
If this response addresses your question, please consider marking it as a solution.
Posted : 07/03/2025 8:07 pm
Kiremit
(@kiremit)
I reached out to OpenAI's developers, and they informed me differently.
Posted : 16/03/2025 12:23 pm
solomon
(@solomon)
What information did they provide? That the official documentation is out of date and they have discontinued prompt caching?
Posted : 16/03/2025 2:20 pm
EuRoBosch
(@eurobosch)
What if we're utilizing Google Gemini? We'll require a new configuration option within the Gemini model node to specify the _cache_name. The request structure appears as follows:
 "contents": [
 "parts":[
 "text": "Please summarize this transcript"
 "role": "user"
 "cachedContent": "'$CACHE_NAME'"
Posted : 02/04/2025 12:57 pm
vkarbovnichy
(@vkarbovnichy)
I'm looking into this as well.
Here's what the OpenRouter documentation states regarding caching:
Gemini isn't mentioned in the documentation. However,
Today, I experimented with the same chat pipeline using Sonnet 3.7 and Gemini 2.5 Pro through OpenRouter. For comparable requests in the middle of a chat (7k input, 500 output tokens), the cost with Sonnet was 43 times higher than with Gemini.
Based on the model costs: $1 per 1k input / $10 per 100k output for Gemini, and $3 per 1k input / $15 per 100k output for Sonnet, the difference should be around 3x, not 43x.
I also observed requests for Gemini where the costs were approximately 10x lower than Sonnet (at the beginning of a dialogue).
Therefore, it's highly likely that automatic caching is being applied for Gemini when using the OpenRouter Model node.
My system prompt alone is 4k tokens.
Posted : 07/04/2025 8:18 pm
vkarbovnichy
(@vkarbovnichy)
I recently discovered that OpenRouter was utilizing my Google AI Studio account key. Consequently, the $300 in trial credits I had there were depleted, with the primary cost being charged to my Google AI Studio account.
After experimenting with API keys and their fallback mechanisms within OpenRouter, I now observe the costs directly in OpenRouter, as it primarily uses Google Vertex.
Posted : 23/04/2025 12:55 pm
ldaniel-jmz
(@ldaniel-jmz)
Do the chat model nodes already include prompt caching?
Posted : 14/06/2025 8:13 pm
AlexJohns
(@alexjohns)
The question seems to be about how to enable explicit context caching to ensure cost savings:
Posted : 14/06/2025 8:27 pm
ktan99
(@ktan99)
I completely agree. I'm hoping that explicit caching will be enabled for the Gemini model mode.
Posted : 17/07/2025 2:25 pm
