How to set up Calli...
How to set up Callin.io in White Label mode for clients
(@michellegrx)
I want to offer Callin.io to my clients under my own brand. I see there’s a White Label option, but I’m not sure how to configure it or what to watch out for with Twilio credentials. Can someone who’s done it explain the basic steps and common pitfalls?
Posted : 08/09/2025 7:56 am
(@lechusai)
Member Admin
I went through this process when I wanted my clients to see everything under my logo and domain instead of Callin.io’s. The White Label setup is straightforward, but there are a few important details:
  1. Twilio credentials.
    In the White Label setup, add your Account SID and Auth Token. They must be named exactly “account_sid” and “auth_token” or it won’t work.
  2. Custom domain.
    Point a subdomain (e.g., app.mycompany.com) to the White Label workspace. This way, clients log in via your brand, not callin.io.
  3. Numbers and traffic.
    Even in White Label mode, calls still run through Twilio. So number purchase/import and caller ID management work the same as in standard mode.
  4. Common mistakes.
  • Using restricted Twilio credentials: make sure the account can handle both calls and numbers.
  • No active number: without one, outbound agents won’t work.
  • Forgetting to test with a real call before inviting a client.
  1. Final test.
    Create a test agent, run one inbound and one outbound call, and confirm both branding and call flow behave as expected.
The best part is that once configured, your client won’t notice Callin.io behind the scenes—they’ll see only your brand and domain.
Posted : 08/09/2025 7:57 am
