Seeking a callin.io...
Seeking a callin.io expert with Google Sheets XP for a consult call
aidy
 aidy
(@aidy)
Hey folks
:wave:
I'm currently setting up callin.io scenarios to extract data from GA4, log it into a Google Sheet, send it to an API, and then record the initial data along with the API response (or a predetermined value based on the response) into a different sheet within the same spreadsheet.
Since this is my first time integrating Google Sheets into this type of workflow, I'm seeking an expert for a consultation call rather than figuring it out through trial and error. The sooner the better.
:smiling_face:
Here's a brief video overview of the workflow, outlining my objectives and current challenges:
https://www.loom.com/share/e271acef97274aea95a31b27b2621181?sid=fa9ead98-bc21-44b5-a43f-7eb94593af60
And the related documentation is available here:
https://whimsical.com/make-data-flow-for-specific-ga-event-reporting-N6Mp6Sb8LvMopsiTvk1TXd
Please send me a direct message with your proposed rate for a consult call and your availability.✌️
(I will prioritize individuals who are available to connect today)
Thanks!
Aidy
p.s. I would have posted this in the Solution Exchange, but it appears I don't yet meet the required level. The category description should contain information on the posting requirements.
Posted : 10/05/2024 11:44 am
Michaela
(@michaela)
Hi there, thanks for the note!
Just a quick heads-up! Everyone has the permissions to post in this category. The key is to pick the section that best suits your inquiry.
:blush:
In your case, that would be
Professional Services.
Anyway, I’m sure you’ll find someone to lend a hand here in no time!
:handshake:
Posted : 10/05/2024 1:14 pm
aidy
 aidy
(@aidy)
Oh, I didn't notice that option in the header bar!
Thanks for the clarification and for moving it to the correct location!
:blush:
Posted : 10/05/2024 1:38 pm
sachinkarma19
(@sachinkarma19)
Yes, we can assist you with this project. We specialize in integrations with Google Sheets to API, and their implementation. We are a partner with callin.io.
Posted : 13/05/2024 10:35 am
aidy
 aidy
(@aidy)
I appreciate the enthusiasm!
Unfortunately, the follow-through from Groww Stacks didn't quite meet expectations. I scheduled a call for today, but the host did not attend.
:face_with_diagonal_mouth:
:man_shrugging:t2:
Posted : 13/05/2024 12:14 pm
sachinkarma19
(@sachinkarma19)
Apologies for the inconvenience; today's schedule is quite hectic due to election activities.
Could you please share your Calendly link?
Posted : 13/05/2024 2:01 pm
Bjorn.drivn
(@bjorn-drivn)
Hey , you could use a combination of Google Apps scripts, Formulas & callin.io to setup a nice integration between the tools. Not sure what exact issues you have right now, but from experience I know that this would already solve a good amount challenges.
Posted : 14/05/2024 11:49 am
Colin
(@colin)
Hey Aidy,
I’m all about streamlining workflows and making data magic happen. Your GA4 to Google Sheets to API flow sounds like a fascinating challenge. I’d love to hop on a call and help you iron out the wrinkles.
You can reach out to me on my email here
Colin
Posted : 15/05/2024 1:55 pm
aidy
 aidy
(@aidy)
Hey there,
Thanks, appreciate you chiming in!
Yup, that’s exactly the route I ended up taking to solve this case
:sweat_smile:
Wasted some time with the G-Sheet perform a function option before going with the Google Apps Script and callin.io webhook route, will share the details below.
Posted : 15/05/2024 7:31 pm
aidy
 aidy
(@aidy)
Update!
Well folks, I ended up taking the path of trial and error
:sweat_smile:
With the help of Claude and GPT I arrived at a working solution that uses a google apps script to:
  • Turn the table data into the correct JSON payload.
  • Runs some deduplication checks.
  • Sends it to a callin.io webhook.
  • Adds payload logs (startTime, endTime, ObjectCount, Status).
  • Then also adds all initial individual row data to another sheet too.
The callin.io scenario uses a JSON parser and Text aggregator to select specific data and prepare it for the API request, with a webhook response to log the response code and message back to the origin sheet.
Following my initial post, I experimented with the Google Sheets Perform A Function module, but soon realised that this didn’t give me enough flexibility in managing a larger payload — which has more to do with Google sheets max char (50k) limit for TEXTJOIN.
Although, I still have some further tweaks to be made as I’ve encountered another issue when I ported over the Apps Script from my test sheet to the live one (under a different G-Workspace domain).
Exception: You do not have permission to call appendRow
The apps script function is invoked when the payload sheet has data.
=IF(COUNTA(A2:A)>0,SendJSONArray(),"No data to push right now")
Weird thing is that I also got this error on my own sheet + apps script, but it ran the requests through anyway
:man_shrugging:t2:
:sweat_smile:
I’ll experiment with an additional helper function column, or go for the time-based trigger instead (former is definitely the preferred option so the script is only invoked when new data comes in).
In the end, the scenarios in callin.io turned out quite simple.
Most of the time I spent amending the apps script to make sure it was sending the data without duplicates, while also accounting for and logging any potential errors.
Thanks for all who chimed in here or via DMs
:v:
p.s. Why I ended up tackling this on my end, instead of pursuing with the initial approach of looping in an expert:
90% of the DMs I received didn’t convince me to hop on a call — none of them had rate nor availability stated for a 1hr consult call.
Of those that wanted to follow through with a conversation, none of them shared a scheduling link, or a link to their website.
For the call that I did book, I was given the link to their listing on the callin.io partner directory, so then I had to navigate to their site and find if/where there was an option to book.
Therein, that call ending up as a no show on their part because they didn’t factor in a public scheduled event into their rep’s availability (something that could be… automated)
Heed this advice partners — if you have a prospect that indicates they’re willing to jump on a paid consult call asap, then you’d best make sure to make it as transparent (rate $) and easy as possible for them to do so. Which should be the default in any case.
:v:t2:
Posted : 15/05/2024 8:54 pm
