[422] error inserti...
[422] error inserting GPT-generated tags into Airtable multi-select field using callin.io
James_Bradford
(@james_bradford)
Hi all — I’m encountering a persistent [422] error when trying to insert GPT-generated tags into a multi-select field in Airtable using callin.io
Scenario Overview
  • I’m using a GPT (OpenAI) response that returns a string of tags like:
mathematica
CopyEdit
Part A, Part L, Structural
  • I split this string into an array with:
callin.io
CopyEdit
split(ComplianceTagsRaw; ", ")
(stored in a Set Variable called ComplianceTagsArray)
  • I then try to insert this into Airtable’s Compliance Tags field, which is:
    • A multi-select field
    • With all expected tags predefined (Part A, Part L, etc.)
    • Map ON is enabled
:red_exclamation_mark: Problem
Despite this, Airtable keeps returning:
pgsql
CopyEdit
[422] Insufficient permissions to create new select option "split(ComplianceTagsRaw; ", ")"
Or:
csharp
CopyEdit
[422] Cannot parse value for field Compliance Tags
I’ve also tried using a Text Aggregator, but it results in this error:
bash
CopyEdit
[422] Insufficient permissions to create new select option "{"text":"{{3[7][1]}}"}{{3[7][1]}}"
This suggests callin.io might still be passing a raw string or an object when Airtable expects a flat string array.
:white_check_mark: What I’ve Confirmed So Far
  • ComplianceTagsArray is an actual array: ["Part A", "Part L", "Structural"]
  • Predefined options in Airtable match GPT output exactly
  • Map ON is toggled correctly
  • All variables are resolved using {{ }} and not typed manually
  • Wand icon is used to select values (not pasted formulas)
:puzzle_piece: Question
How can I reliably insert a split GPT tag list into a multi-select field in Airtable using callin.io?
  • Do I need to use an array aggregator with a specific structure?
  • Should I format it as an array of text objects or just strings?
  • Is there a known quirk where callin.io sends an unresolved formula when mapping from a Set Variable?
Any screenshots, JSON example formats, or complete working flows would be greatly appreciated.
Thanks in advance!
Posted : 23/04/2025 9:07 pm
