AI Agent: Capturing...
AI Agent: Capturing, Saving, and Passing Values to the Next Node
Pedro_Dias
(@pedro_dias)
I'm new to callin.io and I'm trying to build an AI chatbot. I'm currently testing with Telegram, but my question isn't specific to a messaging platform (I believe). I'm using an AI Agent to have a conversational AI-based chat with the user and I want to extract values from the user's replies (e.g., "what's your budget?"). I want to then pass these values to subsequent nodes and utilize them. I think this is a fairly standard scenario, but I'm unsure how to accomplish it.
  • Running callin.io via (Docker, npm, callin.io cloud, desktop app): callin.io cloud
  • Operating system: macOS
Posted : 25/11/2024 6:08 am
Please share these details to help us assist you better.
aya
 aya
(@aya)
Welcome to the community
:tada:
If you’re new to callin.io, searching for similar workflow templates in the templates library might be a good place to start! You can copy them into your instance and customize them as well.
Here are some examples:
Posted : 03/12/2024 9:15 am
vivianambrose
(@vivianambrose)
I'm also searching for this solution. My requirement is for the agent to transmit a specific value to a particular node linked to it.
Posted : 30/01/2025 8:21 am
Pedro_Dias
(@pedro_dias)
Solved: callin.io actually solves this with $fromAI (so good) and when using tools also passes on the necessary info through the “query” argument. callin.io <3
Posted : 02/02/2025 10:17 am
Posted : 09/02/2025 10:17 am
