AI Agent - HubSpot ...
AI Agent - HubSpot Tool - Error with Multiple Customer Properties: Ensure consistent descriptions and types for $fromAI() calls with the same key
dustpickle
(@dustpickle)
When I configure multiple custom properties in the HubSpot Tool, I encounter the following error:
Ensure all $fromAI() calls with the same key have consistent descriptions and types
The properties themselves are distinct, with different descriptions and types.
  • callin.io version: Cloud
  • Database (default: SQLite): N/A
  • callin.io EXECUTIONS_PROCESS setting (default: own, main): Main
  • Running callin.io via (Docker, npm, callin.io cloud, desktop app): Cloud
  • Operating system: Cloud
Posted : 25/02/2025 9:34 pm
Please provide the requested information.
solomon
(@solomon)
I believe this might be a bug.
Could you please try utilizing $fromAI in all those fields instead of allowing the AI to define them?
Refer to the documentation here.
For instance:
:point_right:
If my response resolves your query, please consider marking it as a solution.
Posted : 26/02/2025 8:22 pm
dustpickle
(@dustpickle)
This appears to be a bug. I managed to work around it using your suggestion. Thank you very much.
Posted : 26/02/2025 10:18 pm
Posted : 05/03/2025 10:18 pm
