AI Assistant Not Ut...
AI Assistant Not Utilizing Tools Correctly
moshi
(@moshi)
I'm running into several issues with the AI assistant. My goal is for it to simply call another workflow and pass along the appointment date and time.
Here are the problems I'm experiencing:
  1. Occasionally, it fails to call the tool and instead responds to the user with the tool's name (I've included a screenshot).
  2. Sometimes, it triggers the function when the user mentions a day but not a specific time.
There are also a number of minor errors. Does anyone have a solution for building a straightforward booking assistant that can output the date/time to another workflow?
Posted : 16/05/2024 7:44 pm
Please provide the requested details.
ria
 ria
(@ria)
Hi there!
Could you please share your workflow so we can take a look? You can do this by pasting the JSON content (after downloading the workflow from your workspace) between two block quotes (```).
Typically, the AI Agent's tool functionality involves running another workflow. You can find more information here: Custom callin.io Workflow Tool | callin.io Docs
In the meantime, this template might also be helpful for what you're trying to accomplish:
Posted : 17/05/2024 3:25 pm
moshi
(@moshi)
It’s okay, I've discovered a solution!
I've incorporated a callin.io node following the Ai-Assistant. This node analyzes the last 15 messages to ascertain if the user intends to book an appointment. I've built logic around this JSON output, and I'm finding it to be significantly more accurate.
Essentially, every time a message is sent to the Ai Assistant, another callin.io Node reviews the conversation and generates a JSON detailing the user's intent.
Posted : 17/05/2024 3:46 pm
ria
 ria
(@ria)
That’s fantastic!
:raised_hands:
Have you thought about making it available as a template?
Posted : 23/05/2024 2:56 pm
This thread was automatically closed 90 days following the last response. New responses are no longer permitted.
Posted : 21/08/2024 2:57 pm
