Airtable Filter by ...
Airtable Filter by Formula and IF node
shvz
 shvz
(@shvz)
I'm encountering a bit of a puzzle with what seems like a straightforward task.
I'm performing an API call and then storing an ID in Airtable. My goal is to use a FilterByFormula such that if an ID is not found, it's considered a new post and proceeds to the LLM. However, since I have a batch of 239 items, I need to process them one by one.
I believe my Filter and IF branch are set up correctly. Essentially, if the ID exists in Airtable, the post is already recorded, so the evaluation should be False to skip. If the ID is not found, the evaluation should be True to proceed to the LLM.
Here are my filter and IF conditions. I've tested them: passing a known ID results in False, and passing an unknown ID results in True.
My concern is that since my IF statement is empty, I cannot pass any information from that node to the LLM. The system seems unable to determine which item to use.
Do you have any suggestions on how I can resolve this?
Posted : 19/10/2024 11:03 pm
Please share these details to help us assist you better.
Imperol
(@imperol)
On the OpenAI node, try this:
instead of .item.json
try eg {{ $("DebugHelper").first().json.email }}
Posted : 20/10/2024 8:31 am
Posted : 18/01/2025 8:32 am
