Connecting another ...
Connecting another recordID from Airtable to callin.io
marcogiaff
(@marcogiaff)
Hi everyone,
I’m currently building a new scenario originating from an Airtable database. I've initiated the scenario with Airtable and connected it to my Airtable record ID.
The initial action is linked to a specific record ID associated with a table named “Stories,” and the Airtable automation is linked to it.
I aim to create another action linked to a different table called “Scene.” However, when I attempt to create an Airtable “Get a record” action on callin.io, only the record ID linked to Stories appears, even though I've selected “Scenes” in the “Table” field and have set up the Airtable automation for this second action.
I’m unsure how to retrieve the correct record ID, despite having its number in Airtable.
Does anyone have any suggestions on how to resolve this?
Thank you in advance.
Posted : 05/07/2024 1:43 pm
L_Duperval
(@l_duperval)
Could you share the settings for your Airtable modules?
Posted : 06/07/2024 5:08 pm
Vladimir
(@vladimir)
I'm encountering the same issue. Could you guide me on how to demonstrate this so we can find a solution?
V
Posted : 14/08/2024 1:20 pm
L_Duperval
(@l_duperval)
Hi and welcome to callin.io!
You can send me the information via direct message. Please check the Airtable documentation to see if you can add me as a collaborator with the ‘view-only’ setting for your Airtable setup. I would likely need your client ID or similar to establish a connection.
However, I am out of office until Monday, so I won't be able to assist further until next week.
It might be best for you to create a new topic so that more community members can see it, and perhaps you'll receive an answer sooner.
L
Posted : 15/08/2024 2:05 pm
