Eleven Labs Agent T...
Eleven Labs Agent Timeout Issues
Ashish_Bhatia
(@ashish_bhatia)
I'm currently using the eleven labs voice agent, but the websocket connection is timing out after 20 seconds. This duration isn't sufficient for my callin.io workflow to complete its execution. Consequently, the response isn't being read back to the user. Has anyone else encountered this issue?
  • callin.io version: latest
  • Operating system: Mac OS
Posted : 18/02/2025 8:23 pm
solomon
(@solomon)
Kindly share your workflow details here.
Wrap the JSON code within a code block:
like this
Posted : 24/02/2025 9:57 pm
Posted : 25/05/2025 9:58 pm
