How do I extract ca...
How do I extract callin.io call information
Lane_Carter
(@lane_carter)
What are you trying to achieve?
My objective is to extract approximately 7 pieces of information from Bland calls, which are processed daily in significant volumes, and automatically update this data into a Google Sheet as it becomes available. I've attempted to use the webhook module, but the variables from that webhook module are not appearing in my Sheets module. I'm also working on correctly mapping the data in the analyze a call module to determine if it can help me accomplish this.
Steps taken so far
I have experimented with various modules, published my workflow in callin.io, tested inbound and outbound calls, and configured the webhook settings in Bland.
Screenshots: scenario setup, module configuration, errors
Empty integration.blueprint.json (37.2 KB)
Posted : 07/07/2025 3:51 am
