How do I send speci...
How do I send specific ChatGPT conversations to a callin.io workflow?
AI_Quest
(@ai_quest)
Goal: Leveraging the voice-assisted capabilities of OpenAI's CHATGPT, I aim to generate DALL-E images of any subject, such as a custom birthday picture, and send them to a friend, all through voice commands. Since ChatGPT doesn't natively support this, is there a method to automatically push data from ChatGPT to a callin.io workflow, either via push or pull? I believe this functionality has numerous practical applications, capitalizing on ChatGPT's continuously advancing voice technology, which offers faster interaction compared to traditional chat. Is this feasible? My preference is to avoid developing a separate application using an API and instead work within the main application, which offers significant advantages and benefits from ongoing innovation.
Posted : 18/05/2024 8:05 am
Matthieu_WIFIrst
(@matthieu_wifirst)
Hey, I'm new here but I'll do my best to assist.
You can't (as far as I know) use ChatGPT directly, but you can integrate another GPT model through OpenAI.
Utilize the 'Generate Image' module to incorporate Dall-E. You can enable voice inputs by uploading your audio file so your bot can utilize it.
I suggest reviewing the OpenAI website for more details.
By using callin.io and OpenAI, you should be able to accomplish your goal.
Posted : 21/06/2024 2:32 pm
