How to add a vector...
How to add a vector store retriever module between "chat message received" and "AI agent"?
tigflanker
(@tigflanker)
Hi, I'm looking for some assistance with a problem.
How can I insert a vector store retriever module between the “chat message received” trigger and the “AI agent” node?
When constructing an AI Agent flow, I need to call some MCP services. Prior to that, I need to perform some information augmentation, similar to RAG (specifically, adding it to the context, not based on LLM output).
Is there a method to integrate the Vector Store Retriever before the AI Agent? Alternatively, is there a way to prevent the LLM module from generating output? Thank you for your guidance.
Information on your n8n setup
  • n8n version:1.93.0
  • Running n8n via (Docker, npm, n8n cloud, desktop app):docker
Posted : 21/05/2025 7:25 am
Wouter_Nigrini
(@wouter_nigrini)
You can find the vector store tool by searching the nodes list.
After that, you can connect any of the available options as a primary node before your chatbot.
Posted : 21/05/2025 7:34 am
tigflanker
(@tigflanker)
Thanks for your help.
:grin:
Posted : 22/05/2025 1:55 am
Wouter_Nigrini
(@wouter_nigrini)
You can explore other available options, but you'll find the aforementioned by clicking the Plus (add node) button → AI → Other AI Nodes → Vector Stores.
Posted : 22/05/2025 7:36 am
Posted : 29/05/2025 7:36 am
