How to Build an Aut...
How to Build an Automated Web Scraping Workflow with callin.io and Scrapeless
Scrapeless
(@scrapeless)
We've recently introduced an official integration on callin.io, now available as a public application. This guide will walk you through building a robust automated process that leverages our Google Search API alongside WebUnlocker to extract data from search results, process it using Claude AI, and then send it to a webhook.
What We’ll Build
In this tutorial, we will construct a workflow that:
  1. Initiates automatically each day via integrated scheduling
  2. Performs Google searches for specified queries using the Scrapeless Google Search API
  3. Processes each URL individually using the Iterator module
  4. Scrapes each URL with Scrapeless WebUnlocker to retrieve content
  5. Analyzes the content using Anthropic Claude AI
  6. Dispatches the processed data to a webhook (e.g., Discord, Slack, a database)
Prerequisites
  • A callin.io account
  • A Scrapeless API key (obtain one at scrapeless.com)
  • An Anthropic Claude API key
  • A webhook endpoint (e.g., Discord webhook, callin.io, database endpoint)
  • Basic familiarity with callin.io workflows
Complete Workflow Overview
Your final workflow will appear as follows:
Scrapeless Google Search (with integrated scheduling) → IteratorScrapeless WebUnlockerAnthropic ClaudeHTTP Webhook
Step 1: Adding Scrapeless Google Search with Integrated Scheduling
We will begin by adding the Scrapeless Google Search module, which includes built-in scheduling capabilities.
  1. Create a new scenario in callin.io
  2. Click the + button to add the initial module
  3. Search for “Scrapeless” in the module library
  4. Select Scrapeless and choose the Search Google action
Configuring Google Search with Scheduling
Connection Setup:
  1. Create a connection by entering your Scrapeless API key
  2. Click “Add” and follow the connection setup steps
Search Parameters:
  • Search Query: Input your target query (e.g., “artificial intelligence news”)
  • Language: en (English)
  • Country: US (United States)
Scheduling Setup:
  1. Click the clock icon on the module to access scheduling options
  2. Run scenario: Choose “At regular intervals”
  3. Minutes: Set to 1440 (for daily execution) or your desired frequency
  4. Advanced scheduling: Utilize “Add item” to specify particular times or days if necessary
Step 2: Processing Results with Iterator
The Google Search module returns multiple URLs in an array format. We will employ the Iterator module to handle each result individually.
  1. Add an Iterator module following the Google Search module
  2. Configure the Array field to process the search results
Iterator Configuration:
  • Array: {{1.result.organic_results}}
This configuration will establish a loop to process each search result independently, facilitating improved error management and individual handling.
Step 3: Adding Scrapeless WebUnlocker
Next, we will integrate the WebUnlocker module to scrape content from each URL.
  1. Add another Scrapeless module
  2. Select the Scrape URL (WebUnlocker) action
  3. Utilize the same Scrapeless connection established previously
WebUnlocker Configuration:
  • Connection: Use your existing Scrapeless connection
  • Target URL: {{2.link}} (mapped from the Iterator output)
  • Js Render: Yes
  • Headless: Yes
  • Country: World Wide
  • Js Instructions: `` [{
Posted : 25/06/2025 10:54 am
This thread was automatically closed 30 days following the last response. New replies are no longer permitted.
Posted : 25/07/2025 10:55 am
