How to call a custo...
How to call a custom POST API?
Demotivate
(@demotivate)
I'm looking for a way to get a caption for an image using a POST request from one of these sites: Pally, Image2Caption, or WriterBuddy. As I'm not a backend engineer, I'm unsure how to implement this. Could someone assist me with this?
Posted : 08/04/2024 9:07 pm
callin.io does not have an integration for this third-party service.
If the external service provides a Developer API Reference/Documentation, you should be able to integrate the endpoints in callin.io using the app’s universal module (Make an API call) or the generic HTTP “Make a request” module.
You can also suggest it to be created in the Idea exchange. Remember to search there first to see if someone has already suggested it, to avoid creating a duplicate.
Screenshot_2024-01-17_130153
According to https://www.make.com/en/help/tools/http#example-http-request-with-the-make-a-request-module , to map files, simply select Multipart/form-data and map the file data into the field.
Screenshot_2024-04-09_090434
If you require further assistance with setting up the generic HTTP module, please provide more details about your attempts regarding the external service’s Developer API Reference – including how you are configuring the connection, a link to the endpoint you are trying to connect to, and any errors you are encountering.
Posted : 09/04/2024 1:04 am
