How to capture audi...
How to capture audio files from Telegram
Automate_with_Rezwan
(@automate_with_rezwan)
I'm looking to record audio files that users send as voice messages.
While the watch updates module can do this, it seems to use a lot of operations. Are there alternative methods?
My goal is to build a voice chatbot.
Any suggestions would be appreciated.
Posted : 08/09/2023 5:36 am
Amadio_Gabriel
(@amadio_gabriel)
I think you can utilize the "List update" module, as illustrated in the screenshot. Then, set the "update ID" as the starting offset, indicating where you want to monitor for updates.
However, I still believe "watch updates" is the most suitable approach.
Hope this helps!
Posted : 26/10/2023 4:29 pm
