How to integrate a ...
How to integrate a custom LLM with the AI agent module
simonator
(@simonator)
I am attempting to utilize the AI agent module. However, within the LLM input section, I can only select from a predefined list of LLMs. I am wondering if it's possible to connect to my own LLM via an HTTP call and feed the output into the module.
It simply does not permit non-predefined LLMs to be fed into the module.
A straightforward AI agent that takes my chat message as input and then feeds it into this AI agent. Instead of using the original set of LLMs, I would like to connect to my own using an API call via the HTTP module.
Posted : 21/08/2024 3:37 pm
Please provide the requested information.
ria
 ria
(@ria)
Hi there!
Thanks for posting and welcome to the community!
:partying_face:
We've just launched our locally run AI Starter Kit, which allows you to use custom models as well (at least from the Ollama library).
Currently, the HTTP request node isn't designed to be used as a sub-node for defining a model. However, this sounds like a great feature request – feel free to add it and give it a vote!
:wink:
Posted : 23/08/2024 2:18 pm
simonator
(@simonator)
Thank you for your response and for the warm welcome.
:smiley:
Unfortunately, the AI starter kit might not be suitable for my situation since I cannot run these models locally. I have just submitted a feature request.
Thanks again for your feedback!
Posted : 23/08/2024 3:54 pm
Posted : 21/11/2024 3:54 pm
