How to parse the en...
How to parse the entire email body
Pranav_Ghatraju
(@pranav_ghatraju)
I'm developing an auto-reply system that captures customer replies and stores them in AirTable.
When I utilize the Email module, the Text Content field produces output similar to this:
Hi Pranav,
I am looking forward to our call!
On Sat, Nov 11, 2023 at 12:38 PM Pranav Ghatraju [email protected]
wrote:
Yes definitely!
On Sat, Nov 11, 2023 at 12:37 PM Pranav Ghatraju [email protected]
wrote:
<<<BLOCKQUOTE:
Thank you, looking forward to it.
Could someone help me craft a regex expression? I need to extract only the text preceding the line "On Sat, Nov 11, 2023 at 12:38 PM Pranav Ghatraju [email protected] wrote:". The expression should be flexible enough to handle variations in date, time, and sender email addresses.
Thanks,
Pranav
Posted : 11/11/2023 5:44 pm
Donald_Mitchell
(@donald_mitchell)
I'm not certain if this approach will suit your needs, but you might consider using a Match Pattern Text Parser module with the following pattern:
([sSrn]_?)(?=[rn]On w_, w* d{1,2}, d{4} at)
Here's how the module's options could be configured:
Posted : 11/11/2023 6:56 pm
Pranav_Ghatraju
(@pranav_ghatraju)
Hi Donald,
Thanks for getting back to me!
Unfortunately, that didn't resolve the issue.
Posted : 11/11/2023 8:27 pm
Donald_Mitchell
(@donald_mitchell)
I just realized when I copied and pasted the regex, I forgot to quote it, so markdown took over. You would need to adjust the regex to work with your exact output from the email module.
Posted : 11/11/2023 8:42 pm
