How to rotate throu...
How to rotate through Airtable records (abc, def, ghi, pqr, xyz) with each callin.io scenario run using query strings?
seema_vachhani
(@seema_vachhani)
For example, the first scenario run should call the API URL ?search=abc, the second scenario run should call the API URL ?search=def, the third scenario run should call the API URL ?search=ghi, the fourth scenario run should call the API URL ?search=pqr, the fifth scenario should call the API URL ?search=xyz, the sixth scenario run should call the API URL ?search=abc, and so on.
Posted : 05/08/2024 6:29 am
ManishMandot
(@manishmandot)
You can store your keywords in a datastore or Google Sheets. This allows you to iterate through the keywords and use them in subsequent modules.
Posted : 05/08/2024 12:39 pm
How frequently does your scenario execute?
Posted : 05/08/2024 1:00 pm
seema_vachhani
(@seema_vachhani)
Could you please provide more details?
My assignment specifies that the keywords need to be stored in Airtable.
Posted : 05/08/2024 1:56 pm
seema_vachhani
(@seema_vachhani)
I haven't scheduled it yet. For now, I'm just using the 'run once' option.
Posted : 05/08/2024 3:19 pm
