How to use variable...
How to use variables after a true/false split?
Bryce_Claudin
(@bryce_claudin)
Hello. This is a workflow designed to manage the conclusion of an AI-powered phone call. The objective is to parse the call transcript to extract caller details from the conversation.
In this specific segment of the workflow, the aim is to verify if the transcript is available. If it IS AVAILABLE, the information will be parsed and variables will be populated with this parsed data. Conversely, if it is NOT AVAILABLE, the variables should be set to empty values.
However, this approach presents a challenge: to utilize the variables, one must select one of the update variable nodes as the input. What are the possible solutions to address this situation?
Posted : 23/06/2024 6:54 pm
barn4k
(@barn4k)
Hello!
Could you please share the workflow?
Posted : 25/06/2024 9:01 am
BramKn
(@bramkn)
You are probably looking for an expression like.
{{$('nodename').first(0,0).json.variablename}}
Posted : 25/06/2024 11:33 am
Posted : 23/09/2024 11:34 am
