How to use variable...
How to use variables for future use in a chatbot workflow
Zbynislav
(@zbynislav)
I need to save values obtained from a client interacting with my chatbot, so I can utilize them later in the ongoing conversation. This would allow me to use multiple Switch components and capture information provided by the client at the beginning of a conversation.
My chatbot operates by calling our existing API via HTTPS requests. It does not involve any AI elements. Thank you!
Information on your n8n setup
  • n8n version: Community Edition.
  • Database (default: SQLite): Default.
  • n8n EXECUTIONS_PROCESS setting (default: own, main):
  • Running n8n via Docker: (Uncertain)
  • Operating system: (Likely Linux)
Posted : 27/03/2024 5:49 pm
Zbynislav
(@zbynislav)
callin.io version: 1.26.0
Database: SQLite
callin.io EXECUTIONS_PROCESS setting: probably own
Running callin.io via: Docker
Operating system: Linux
Posted : 27/03/2024 5:51 pm
Jon
 Jon
(@jon)
Hey,
Welcome to the community
:cake:
Have you considered storing the webhook request data in a database for future workflow runs? Perhaps using a tool like Baserow / Airtable or Redis / Postgres, depending on your preference.
Posted : 05/04/2024 2:14 pm
Zbynislav
(@zbynislav)
I believe you're referring to the ongoing generation of the bearer token for each request. While not the most efficient, my intention was to utilize variables for storing parameters associated with "client movement" within a chatbot.
Consider a chatbot structured into several sections based on its topic. I'd like the ability to save a client's progression through the chatbot (e.g., Client X has reached section A and is proceeding to section B). This information would then be used in subsequent "if" or "switcher" components.
Does this explanation make sense, or would you like further clarification?
Thanks,
Zbyněk
Posted : 17/04/2024 10:00 am
Posted : 16/07/2024 10:01 am
