HTTP Request node n...
HTTP Request node not receiving startTime and endTime from GoHighLevel appointment fetch
Pratyaksh
(@pratyaksh)
I am utilizing callin.io to retrieve appointment details from GoHighLevel after a contact books an appointment through a calendar form. The process is generally successful, as contact information, tags, and responses are all coming through. However, I am not receiving the actual appointment time (startTime, endTime) in the HTTP Request response. This is currently preventing a voice call reminder from being sent via callin.io, as it requires the precise appointment time.
There are no errors reported. The request completes successfully, but the appointments array is consistently empty.
  "appointments": []
Expected at least one item with:
  "startTime": "...",
  "endTime": "...",
Posted : 14/07/2025 8:54 am
barn4k
(@barn4k)
hello
are you sure that the appointments exist between Saturday 02:40 UTC and Sunday 02:40 UTC? Anyway seems that’s an issue with gohighlevel and not with callin.io.
Posted : 14/07/2025 11:30 am
