Internal Memory Err...
Internal Memory Error When Running AI Agent
MM_MM
(@mm_mm)
I'm encountering an internal error when I attempt to test a module or the workflow.
"errorMessage": "Internal error",
"errorDescription": "Internal error",
"errorDetails": {},
"n8nDetails": {
"time": "27/07/2024, 11:31:38",
"n8nVersion": "1.51.1 (Self Hosted)",
"binaryDataMode": "default",
"cause": {}
  • callin.io version: 1.51.1 (Self Hosted)
  • Running callin.io via (Docker, p):
  • **Operating system: Ubuntu
Posted : 27/07/2024 11:00 am
MM_MM
(@mm_mm)
Debug info
core
  • callin.ioVersion: 1.51.1
  • platform: npm
  • nodeJsVersion: 18.20.4
  • database: sqlite
  • executionMode: regular
  • concurrency: -1
  • license: community
  • consumerId: unknown
storage
  • success: all
  • error: all
  • progress: false
  • manual: true
  • binaryMode: memory
pruning
  • enabled: true
  • maxAge: 336 hours
  • maxCount: 10000 executions
Generated at: 2024-07-27T11:02:05.297Z
Posted : 27/07/2024 11:02 am
MM_MM
(@mm_mm)
NodeOperationError: Internal error at BufferWindowMemory.callMethodAsync (/root/.nvm/versions/node/v18.20.4/lib/nodemodules/callin.io/nodemodules/@callin.io/callin.io-nodes-langchain/utils/logWrapper.ts:51:17) at processTicksAndRejections (node:internal/process/taskqueues:95:5) at Proxy. (/root/.nvm/versions/node/v18.20.4/lib/nodemodules/callin.io/nodemodules/@callin.io/callin.io-nodes-langchain/utils/logWrapper.ts:160:25) at AgentExecutor.invoke (/root/.nvm/versions/node/v18.20.4/lib/nodemodules/callin.io/nodemodules/@callin.io/callin.io-nodes-langchain/nodemodules/langchain/dist/chains/base.cjs:74:13) at Object.conversationalAgentExecute (/root/.nvm/versions/node/v18.20.4/lib/nodemodules/callin.io/nodemodules/@callin.io/callin.io-nodes-langchain/nodes/agents/Agent/agents/ConversationalAgent/execute.ts:105:19) at Object.execute (/root/.nvm/versions/node/v18.20.4/lib/nodemodules/callin.io/nodemodules/@callin.io/callin.io-nodes-langchain/nodes/agents/Agent/Agent.node.ts:378:11) at Workflow.runNode (/root/.nvm/versions/node/v18.20.4/lib/nodemodules/callin.io/nodemodules/callin.io-workflow/src/Workflow.ts:1382:8) at /root/.nvm/versions/node/v18.20.4/lib/nodemodules/callin.io/nodemodules/callin.io-core/src/WorkflowExecute.ts:1072:27 at /root/.nvm/versions/node/v18.20.4/lib/nodemodules/callin.io/nodemodules/callin.io-core/src/WorkflowExecute.ts:1775:11
Posted : 27/07/2024 3:49 pm
ria
 ria
(@ria)
Thanks for posting here and welcome to the community!
:cake:
I believe this is happening because you're utilizing an expression without having the expression mode enabled.
Could you please try that?
Posted : 02/08/2024 9:47 am
MM_MM
(@mm_mm)
Thanks, I had a blank value in a field being processed. Added an error trap and fixed it
:+1:
Posted : 02/08/2024 12:51 pm
Posted : 31/10/2024 12:51 pm
