Issue with AI agent...
Issue with AI agent and workflow tools
Vasilii_Danilin
(@vasilii_danilin)
Hi everyone!
I'm encountering an issue connecting the AI agent node with a workflow tool that the AI agent is supposed to call.
The AI agent is meant to invoke this workflow to generate an image using Midjourney. This functionality was working just two days ago. However, now when I ask the agent to create a picture, it calls the workflow tool (which executes without any problems), but after about three seconds, it reports that no response was received, even though the workflow tool is still actively working on the creation.
How can I resolve this?
Thanks!
  • callin.io version: 1.65.2
  • **Database (default: SQLite):
  • **callin.io EXECUTIONS_PROCESS setting (default: own, main):
  • **Running callin.io via (Docker, npm, callin.io cloud, desktop app): cloud
  • **Operating system: windows
Posted : 15/11/2024 1:25 pm
Vasilii_Danilin
(@vasilii_danilin)
Can anyone assist me, please?
Posted : 25/11/2024 4:41 pm
Vasilii_Danilin
(@vasilii_danilin)
I'm really unsure about what to do next...
Could someone please offer some guidance?
Posted : 29/11/2024 9:20 pm
aya
 aya
(@aya)
Apologies that you're encountering issues with the workflow and for the delay in response. The screenshot is useful, but it would be even more beneficial if you could share the workflow JSON so we can attempt to replicate the problem. Thank you!
:star2:
Tip for sharing your workflow in the forum
Pasting your callin.io workflow
Please copy your callin.io workflow and paste it into a code block, enclosed by triple backticks. Alternatively, you can click the </> (preformatted text) button in the editor and paste your workflow there.
<your workflow>
Ensure you have removed any sensitive information from your workflow and included dummy or pinned data wherever possible!
Please provide the workflow JSON.
Posted : 03/12/2024 2:08 pm
Vasilii_Danilin
(@vasilii_danilin)
Hi there! Thank you very much for responding. Here is the JSON of the main workflow. Should I send you the JSON of the tool workflows?
Posted : 03/12/2024 3:28 pm
Vasilii_Danilin
(@vasilii_danilin)
Hi!
Have you found any solution?
Posted : 11/12/2024 8:39 am
Posted : 11/03/2025 8:39 am
