Issue with OpenAI n...
Issue with OpenAI node (ChatGPT) stuck on "Executing node.."
Haniel_Compaore
(@haniel_compaore)
I'm reaching out because I've encountered an issue for the past two days that I haven't been able to resolve through Google or YouTube searches. As I'm new to callin.io, I'm building a workflow for content creation and facing a problem: the OpenAI node is stuck in "executing mode" and isn't returning any output. I'm unsure about the cause, as I've double-checked all the settings and they appear to be correct. Does anyone have any suggestions?
The prompt for the node is sourced from a Google Sheets file and is quite lengthy. Could this be the reason for the issue? (This would be unusual, as it works without problems with callin.io).
I conducted a test using a shorter prompt, and it did work. However, I can't find a logical explanation for the difference in behavior between a long and a short prompt.
callin.io setup information:
  • callin.io version: Version 1.27.3
  • Docker
Posted : 16/02/2024 4:05 pm
Please provide the requested information.
EmeraldHerald
(@emeraldherald)
Hi there!
:wave:
Welcome to the community!
:tada:
While I can't explain why it might behave differently on another platform, it appears you're making 187 calls to the Open AI node, which will unfortunately take some time.
:sweat_smile:
If feasible, you could try splitting these calls up so the node has fewer items to process. Otherwise, it will likely be slower with that many requests simultaneously.
Posted : 20/02/2024 2:51 pm
Posted : 20/05/2024 2:52 pm
