Level 2 - Combining...
Level 2 - Combining and adding data to Airtable
BeardedWarlock
(@beardedwarlock)
I'm working through the level 2 course and have configured the nodes correctly according to the instructions. However, I'm encountering an issue where the fields.region and fields.subregion are not updating from the name.region and name.subregion fields in the HTTP feed. When I merge these, the output (set to both inputs merged) shows that the matching is happening correctly.
After the merge, I proceed to the Airtable update node. I've set the correct Base and Table IDs, but the update isn't occurring. Using 'All Fields' results in an error, so I've attempted to update fields individually. My question is, how do I specify that fields.region should be updated with the value from name.region?
Nodes
Merge
AirTable (this shows the correct matching on the left but no update on left)
I hope you can assist (please!)
Posted : 27/07/2023 2:09 pm
jesperbylund
(@jesperbylund)
If it’s just the fields.region that is missing, you can do the following: Before the update node, add a set node that changes the name of name.region to fields.region.
Posted : 27/07/2023 2:31 pm
BeardedWarlock
(@beardedwarlock)
Thanks, that really helped clarify things. I believe I need to use the ID from Airtable for the record ID. However, as soon as I do, I get this error:
ERROR: Your request is invalid or could not be processed by the service
You must provide an array of up to 10 record objects, each with an “id” ID field and a “fields” object for cell values.
I've searched the forum for this, but I'm a bit of a beginner and got a bit lost with the responses.
Does anyone have any suggestions?
Posted : 27/07/2023 3:29 pm
BeardedWarlock
(@beardedwarlock)
Understood. For some reason throughout this process, my Airtable fields were contained within an array named fields. So, while the SET control was utilized to resolve this (thanks jesperbylund), I also had to rename the ID field in Airtable. It is now updating correctly.
Thanks for the assistance.
Posted : 27/07/2023 3:36 pm
EmeraldHerald
(@emeraldherald)
Thanks for posting your solution!
Posted : 03/08/2023 3:36 pm
