LinkedIn connection...
LinkedIn connection error: 403 Not enough permissions
taras_nile
(@taras_nile)
I'm attempting to establish a connection with LinkedIn. The objective is to perform straightforward API calls concerning an organization page that I administer on LinkedIn.
When I set up the connection, LinkedIn indicates that callin.io has requested the following permissions:
My module makes the following request:
(14. Result and 2. Result are both correct – millisecond unix timestamps)
This returns the following error:
The frustrating aspect here is that this functioned flawlessly on my free account. I then transferred it to my organization's Pro shared workspace, and my LinkedIn connection ceased to operate.
However, when I removed the connection from the old account and re-established it, it failed in a similar manner.
I have attempted to remove the connection on both ends and recreate it, without success.
Does anyone have any suggestions? Thank you!
Posted : 06/02/2024 3:55 pm
Try setting up the connection again. It appears you only granted the Name & Photo permission, but not access to other permissions.
Posted : 06/02/2024 4:29 pm
taras_nile
(@taras_nile)
Could you please explain how? callin.io does not offer the option of requesting any other permissions when creating a new LinkedIn connection.
Posted : 06/02/2024 4:41 pm
alex.newpath
(@alex-newpath)
Yeah I tried this as well and I was only asked to share name and Photo. I don’t see any other credentials being requested:
Posted : 06/02/2024 4:43 pm
alex.newpath
(@alex-newpath)
It appears that when I attempt to use another module, such as “List an Organization’s Posts,” the access permissions are requested to be extended at that point:
I'm still uncertain if that will be sufficient to gain access to the endpoint you're attempting to reach, but it's certainly worth a shot.
Posted : 06/02/2024 4:56 pm
taras_nile
(@taras_nile)
Solved!!! Thanks!
I must have done that a while ago on my old account before I started experimenting with ‘Make an API call’.
Posted : 06/02/2024 4:57 pm
alex.newpath
(@alex-newpath)
There is a Get Page Statistics module that I believe provides what you need without needing to make an API call:
However, I see there's no granularity or start/end time available, which explains why you're using the endpoint.
Posted : 06/02/2024 4:59 pm
taras_nile
(@taras_nile)
Yes, I require it to be restricted to a calendar month.
Posted : 06/02/2024 5:14 pm
