Mapping Airtable Ba...
Mapping Airtable Bases and Tables
Markus1
(@markus1)
Hello Automation Community,
does anyone know why you can map Bases and Tables in the “Get a record” module, but it’s not possible when you update or create a record in Airtable?
Is the only workaround to call Airtable’s API manually?
air mapping
Regards
Markus
Posted : 04/06/2024 9:27 pm
mania_braun
(@mania_braun)
Hi again Markus,
You can make the API call to Airtable using the corresponding request:
Posted : 04/06/2024 9:55 pm
Markus1
(@markus1)
Hello Mania,
yeah, thank you again
:wink:
I will check your hint and try it.
Hope, I am configuring it the right way… I will let you know!
Thank you
Markus
Posted : 05/06/2024 10:06 am
Markus1
(@markus1)
After extensive work with callin.io and Airtable today, I'm now exclusively using the Airtable API call module in my current scenario for tasks like deleting records, updating them, and creating new ones. This approach allows me to map everything, making my scenario adaptable for any base or user within my workspace.
:wink:
Getting the JSON right was a bit challenging, but I managed it!
Thanks again for your guidance and suggestions!
Markus
Posted : 05/06/2024 10:03 pm
