Need help automatin...
Need help automating markdown file creation from transcribed speech with callin.io
aiaiai
(@aiaiai)
Description:
I'm attempting to automate the creation of Markdown files from transcribed speech using callin.io on my Raspberry Pi. The objective is to store these files locally and enable voice-command-based searches of the content.
Current Setup:
  • I've developed a workflow in callin.io, triggered via Telegram, which is functioning correctly.
  • The workflow utilizes an AI agent through the ChatGPT API.
  • The output is successfully generated and transcribed.
  • callin.io version: 1.77.3
Issue:
I'm uncertain about the process for automatically creating and saving these transcriptions as Markdown files on my Raspberry Pi. The files should be named with a timestamp and contain the transcribed text from the AI agent.
Any advice on how to accomplish this would be greatly appreciated!
Thank you!!
Posted : 26/02/2025 2:33 pm
It appears your topic is missing some crucial details. Could you please provide the following information, if it applies?
Please provide the details above.
Ruslan_Yanyshyn
(@ruslan_yanyshyn)
You can achieve this using a setup similar to the following.
Posted : 26/02/2025 5:01 pm
aiaiai
(@aiaiai)
Awesome! Glad to hear that was helpful!
Posted : 27/02/2025 4:08 pm
Posted : 06/03/2025 4:09 pm
