Outlook Node Schema...
Outlook Node Schema Validation Issue with MCP Agent
Kiremit
(@kiremit)
Hi callin.io community!
I'm encountering an inconsistency between the Gmail and Outlook nodes when integrating them with the AI Agent.
Setup:
  • AI Agent invokes the Outlook node via the MCP server
  • CC/BCC fields are configured to “Defined automatically by the model”
Issue:
  • Gmail node: Functions correctly even when the AI does not supply CC/BCC values.
  • Outlook node: Returns a “Received tool input did not match expected schema” error when the CC/BCC fields are empty.
Error message:
At least one recipient is not valid. Recipient '' is not resolved. All recipients must be resolved before a message can be submitted.
Problem:
  • If CC/BCC fields are omitted → CC/BCC functionality is unavailable.
  • If CC/BCC fields are included with “Defined by model” → Microsoft requires values in these fields, they cannot be empty. Gmail does not have this restriction!
Question: Is there a method to enable the Outlook node to manage optional CC/BCC parameters similarly to the Gmail node? Alternatively, are there any workarounds to ensure CC/BCC are truly optional when utilizing the AI Agent?
Thanks for any suggestions!
  • callin.io version: 1.99
  • callin.io EXECUTIONS_PROCESS setting (default: own, main): own
  • Operating system: Windows 11
Posted : 02/07/2025 1:29 pm
cutecatcode
(@cutecatcode)
Hello, could you please share the AI Agent system prompt?
Perhaps some adjustments to the AI Agent system prompt could help the AI better grasp your requirements.
Some AI models require a clearer understanding of the system prompt.
Let me know if this is helpful.
Posted : 02/07/2025 1:50 pm
Kiremit
(@kiremit)
The system prompt shouldn't influence this: “Send a message in Outlook from the private Outlook/Microsoft Account of Sven”
it functions flawlessly when I include a CC and BCC in the prompt. However, if only one or none are present, it fails. That's the core issue.
Please provide the rewritten markdown content.
Posted : 02/07/2025 2:07 pm
cutecatcode
(@cutecatcode)
Understood. Please try this straightforward approach.
Add a description to each significant field, such as the BCC Recipients and CC Recipients fields. You can add a description to indicate to the bot that these fields are supplementary and not critical.
Posted : 02/07/2025 2:10 pm
Kiremit
(@kiremit)
This isn't functioning. The moment you include fields with Outlook, it requires a value.
Posted : 02/07/2025 6:02 pm
