Problem with parall...
Problem with parallel pattern using AI Agent tool call
Thomas_Wink
(@thomas_wink)
I've implemented the parallel pattern as detailed in the callin.io documentation (utilizing callbacks). It functions correctly, with the exception of when the main flow is invoked by a tool called by an AI agent.
What's occurring is that the 'respond to webhook' output is immediately returned to the AI agent, meaning there's no actual wait for the main flow to complete. However, I need the agent to wait until the workflow finishes before proceeding.
Am I overlooking something? Is this a bug, or is there a potential workaround?
The workflows:
“nodes”: [
“parameters”: {
“options”: {}
“type”: "@callin.io/n8n-nodes-langchain.chatTrigger",
“typeVersion”: 1.1,
“position”: [
0,
0
“id”: "cd5d4c62-b47b-4647-a313-ff5cf10a41f5",
“name”: "When chat message received",
“webhookId”: "5b8d6b75-6ab4-42a9-a9eb-005f2bb7161f"
“parameters”: {
“options”: {}
“type”: "@callin.io/n8n-nodes-langchain.agent",
“typeVersion”: 1.8,
“position”: [
220,
0
“id”: "6b3b8cdd-8441-4681-9787-0cffa597bc50",
“name”: "AI Agent"
“parameters”: {
“model”: "gpt-4o-mini",
“options”: {}
“type”: "@callin.io/n8n-nodes-langchain.lmChatAzureOpenAi",
“typeVersion”: 1,
“position”: [
260,
220
“id”: "942c573e-1f95-4108-81b5-69ee54318971",
“name”: "Azure OpenAI Chat Model",
“credentials”: {
“azureOpenAiApi”: {
“id”: "iKY0wB5wcFToSq7t",
“name”: "Azure gpt-40-mini"
“parameters”: {
“name”: "pptool",
“workflowId”: {
rl”: true,
“value”: "iue5rBXxnFXZd8MK",
“mode”: "list",
“cachedResultName”: "Parallel Exec with wait MAIN flow - template"
“workflowInputs”: {
“mappingMode”: "defineBelow",
“value”: {},
“matchingColumns”: ,
“schema”: ,
“attemptToConvertTypes”: false,
“convertFieldsToString”: false
“type”: "@callin.io/n8n-nodes-langchain.toolWorkflow",
“typeVersion”: 2.1,
“position”: [
380,
220
“id”: "334d73cc-1568-47a0-8a45-89e2d8560be1",
“name”: "Call n8n Workflow Tool"
“connections”: {
“When chat message received”: {
“main”: [
“node”: "AI Agent",
“type”: "main",
“index”: 0
“Azure OpenAI Chat Model”: {
“ai
languageModel”: [
“node": "AI Agent",
“type”: "ailanguageModel",
“index”: 0
“Call n8n Workflow Tool”: {
“ai
tool”: [
“node": "AI Agent",
“type": "ai_tool",
“index": 0
“pinData”: {},
“meta”: {
“instanceId": "58aa91dfb81527f3ab9d46e751edfcf1e8801ddcdd145e7779c36f37dcdfa475"
“nodes”: [
“parameters”: {
“jsCode”: "// an example item for the loop/split outnconst myData = [n {id: 1, content: ‘String one’},n {id: 2, content: ‘String two’}n];nreturn myData;"
“type”: "n8n-nodes-base.code",
“typeVersion”: 2,
“position”: [
280,
0
“id”: "2b3aa72b-771a-45a6-8ab3-9a4182d95e2f",
“name”: "Generate item with x objects"
“parameters”: {
“options”: {}
“type”: "n8n-nodes-base.splitInBatches",
“typeVersion”: 3,
“position”: [
500,
0
“id”: "dc3135df-414b-4d94-a92c-d10f29df2b49",
“name”: "Loop Over Items"
“parameters”: {
“resume”: "webhook",
“httpMethod”: "POST",
“responseMode”: "responseNode",
“options”: {}
“type”: "n8n-nodes-base.wait",
“typeVersion”: 1.1,
“position”: [
1340,
120
“id”: "04bbb998-967d-4b7d-b0ec-315acb04efa0",
“name”: "Listen for subflow callback",
“webhookId”: "1e99daa4-e050-4a46-aba5-8b68bcfc6e49"
“parameters”: {
“method”: "POST",
“url”: " https://n8n-host/webhook/parallel-webhook-call ",
“sendHeaders”: true,
“headerParameters”: {
“parameters”: [
“name”: "=callbackurl",
“value”: "={{ $execution.resumeUrl }}"
“sendBody”: true,
“bodyParameters”: {
“parameters”: [
“name": "id",
“value”: "={{ $json.id }}"
“options”: {}
“type”: "n8n-nodes-base.httpRequest",
“typeVersion”: 4.2,
“position”: [
720,
160
“id”: "eccbaac8-94e0-48bb-ae6f-a435f6a3ac8b",
“name”: "HTTP call subflow"
“parameters”: {
“jsCode”: "let result = $(‘Listen for subflow callback’).first().json.body;nnlet json = $(‘test endResult cnt’).first().json;nif (!json.endResult) json.endResult = ; //initnnjson.endResult.push(result);nnreturn [json]"
“typeVersion”: 2,
“position”: [
1520,
120
“id”: "6928941d-f850-47ed-bf13-6c4b140b86ce",
“name": "Add execution result"
“parameters”: {
“conditions”: {
“options”: {
“caseSensitive”: true,
“leftValue”: "",
“typeValidation”: "strict",
“version”: 2
“conditions”: [
“id”: "99603d4a-4e96-4df9-b1bd-4f1cda6d8444",
“leftValue”: "={{ $json.endResult.length }}",
“rightValue”: "={{ $(‘Generate item with x objects’).all().length }}",
“operator”: {
“type”: "number",
“operation”: "equals"
“combinator”: "and"
“options”: {}
“type”: "n8n-nodes-base.if",
“typeVersion”: 2.2,
“position”: [
1120,
40
“id”: "b2419ac4-fdea-4b7b-a7a2-e15903ced7da",
“name": "test endResult cnt"
“parameters”: {
“options”: {}
“type”: "n8n-nodes-base.respondToWebhook",
“typeVersion”: 1.1,
“position”: [
1700,
120
“id”: "f6d4ce81-a994-45b1-abac-e45518e98b7a",
“name": "Ack subflow"
“parameters”: {},
“typeVersion”: 1.1,
“position”: [
1700,
-120
“id": "52dcc50f-08be-4648-9c63-2f416b6afca5",
“name": "Yes, we made it",
“webhookId": "af3a03a0-5276-4358-b21d-4d7975171265"
“parameters”: {
“content”: "## Call parallel subflows nUses http call node",
“height”: 640,
“width”: 940
“type”: "n8n-nodes-base.stickyNote",
“typeVersion”: 1,
“position”: [
-40,
-200
“id”: "b50ada1d-4abf-4b57-b364-cf12e74ebe04",
“name”: "Sticky Note"
“parameters”: {
“content": "# Wait for subflows to report back inn
jib",
“height”: 640,
“width”: 940
“typeVersion”: 1,
“position”: [
1000,
-200
“id": "a197a4ec-04b7-4a78-a8bf-937b43871e7d",
“name": "Sticky Note1"
“parameters”: {
“options”: {}
“type": "n8n-nodes-base.respondToWebhook",
“typeVersion”: 1.1,
“position”: [
1920,
-120
“id”: "8c14a086-7389-4bcc-8166-b1c080707231",
“name": "Respond to Webhook"
“parameters": {
“inputSource": "passthrough"
“type": "n8n-nodes-base.executeWorkflowTrigger",
“typeVersion”: 1.1,
“position”: [
0,
0
“id": "efc1986a-12c6-46bb-a013-22e3c528867a",
“name": "When Executed by Another Workflow"
“connections”: {
“Generate item with x objects”: {
“main”: [
“node”: "Loop Over Items",
“type": "main",
“index": 0
“Loop Over Items”: {
“main”: [
“node": "test endResult cnt",
“type": "main",
“index": 0
“node": "HTTP call subflow",
“type": "main",
“index": 0
“Listen for subflow callback”: {
“main”: [
“node": "Add execution result",
“type": "main",
“index": 0
“HTTP call subflow”: {
“main”: [
“node": "Loop Over Items",
“type": "main",
“index": 0
“Add execution result”: {
“main”: [
“node": "Ack subflow",
“type": "main",
“index": 0
“test endResult cnt”: {
“main”: [
“node": "Yes, we made it",
“type": "main",
“index": 0
“node": "Listen for subflow callback",
“type": "main",
“index": 0
“Ack subflow”: {
“main”: [
“type": "main",
“index": 0
“Yes, we made it”: {
“main”: [
“node": "Respond to Webhook",
“type": "main",
“index": 0
“When Executed by Another Workflow”: {
“main”: [
“node": "Generate item with x objects",
“type": "main",
“index": 0
“pinData”: {},
“meta”: {
“nodes”: [
“parameters”: {
“jsCode": "// Loop over input items and add a new field called ‘myNewField’ to the JSON of each onenfor (const item of $input.all()) {n item.json.addition = ‘Data added by subflow’;n}nnreturn $input.all();"
“typeVersion”: 2,
“position”: [
440,
0
“id": "012a8cb9-a387-48ba-bc37-e0bec572f884",
“name": "Generate subflow data (do stuff)"
“parameters”: {
“httpMethod": "POST",
“path": "parallel-webhook-call",
“responseMode": "responseNode",
“options”: {}
“type": "n8n-nodes-base.webhook",
“typeVersion”: 2,
“position”: [
0,
0
“id": "1c94229e-35de-4fe4-ae33-6cd907667d6d",
“name": "Webhook",
“webhookId": "b115cd5b-8624-47fb-a710-a3fd08aa8326"
“parameters”: {
“method": "POST",
“url": "={{ $(‘Webhook’).item.json.headers.callbackurl }}",
“sendBody”: true,
“bodyParameters”: {
“parameters”: [
“name": "returnStatus",
“value": "=1"
“name": "id",
“value": "={{ $(‘Webhook’).item.json.body.id }}"
“options”: {}
“typeVersion”: 4.2,
“position”: [
900,
0
“id": "d9305549-d610-4307-a66d-1afda9155963",
“name": "Send result back to main flow",
“retryOnFail”: true
“parameters": {
“options”: {}
“typeVersion”: 1.1,
“position”: [
220,
0
“id": "f8939365-0cfd-4159-8e3e-6f34f98dddac",
“parameters": {
“amount": "={{ Math.ceil(Math.random() * (5 - 2) + 2) }}"
“typeVersion”: 1.1,
“position”: [
660,
0
“id": "666119fe-9cf7-41fa-9e71-b3ea5be1fb91",
“name": "Wait random 2-5 secs",
“webhookId": "d4515c9b-5b72-47d8-af36-550dd58e103e"
“connections”: {
“Generate subflow data (do stuff)”: {
“main”: [
“node": "Wait random 2-5 secs",
“type": "main",
“index": 0
“Webhook”: {
“main”: [
“type": "main",
“index": 0
“Send result back to main flow”: {
“main": [
“Respond to Webhook”: {
“main”: [
“node": "Generate subflow data (do stuff)",
“type": "main",
“index": 0
“Wait random 2-5 secs”: {
“main”: [
“node": "Send result back to main flow",
“type": "main",
“index": 0
“pinData”: {},
“meta”: {
  • callin.io version: Version 1.88.0
  • Database: sqlite
  • callin.io EXECUTIONS_PROCESS default:
  • Running callin.io via Docker compose:
  • Operating system: Debian Linux 12
Posted : 19/04/2025 5:05 pm
Saikalyan_Akunuri
(@saikalyan_akunuri)
From what I could gather, it seems your workflow is returning results before the tasks are fully completed. The Langchain tool in callin.io is designed to respond quickly to prevent the AI from hanging or waiting excessively. My suggestion is to move all your parallel tasks out of the AI-triggered workflow and into a separate sub-workflow. Then, call this sub-workflow from within the AI-triggered workflow, ensuring it waits for all tasks to finish before sending a reply.
Posted : 19/04/2025 5:51 pm
Thomas_Wink
(@thomas_wink)
Thanks for the suggestion. I gave it a try, but the behavior remains the same when I implement a caller flow, even with the 'wait for subflow to complete' option enabled.
What's happening is that the Wait node (configured to resume on webhook call) is returning data, which is causing this behavior.
I've implemented the following example from the documentation, where the “Webhook Callback Wait” clearly returns data to the calling workflow on the initial callback it receives.
Parallel pattern example: Pattern for Parallel Sub-Workflow Execution Followed by Wait-For-All Loop | callin.io workflow template
Posted : 21/04/2025 11:18 am
Saikalyan_Akunuri
I believe the main workflow does initiate the sub-workflow. However, after the loop, there's an IF node that verifies if all jobs have been completed before proceeding. A screenshot of your workflow would be beneficial, but I suspect you might be using a Wait node that resumes upon any callback. The example, though, doesn't utilize the Wait node in that manner. In the example, the IF condition checks if all jobs are finished; if not, it waits, functioning more like a polling mechanism that only exits once all jobs are executed.
Posted : 21/04/2025 2:13 pm
Thomas_Wink
(@thomas_wink)
Please see the attached screenshots. The issue is that as soon as the first “Listen for subflow callback” node receives data, an empty object is sent to the trigger flow. I confirmed this by adding a 10-second wait before that node, running the workflow, and then comparing it to a run with a 10-second wait node placed afterward.
Trigger flow:
Main flow:
Sub flow:
Posted : 01/05/2025 1:43 pm
