Problem with the HT...
Problem with the HTTP Request Tool
Andrea_Santaniello
(@andrea_santaniello)
I'm attempting to retrieve JSON data from our backend, which contains a list of doctors from our platform. The node is failing with the error "Received tool input did not match expected schema" without any further details. It's a straightforward unauthenticated GET request (I've copied an example output to pastebin if you'd like to test it).
Any insights?
Workflow
Last node output
Item Index
0
Node type
@n8n/n8n-nodes-langchain.openAi
Node version
1.5 (Latest)
n8n version
1.61.0 (Self Hosted)
Time
4/10/2024, 17:57:58
Stack trace
NodeOperationError: Received tool input did not match expected schema at Object.router (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/nodes/vendors/OpenAi/actions/router.js:86:19) at processTicksAndRejections (node:internal/process/task_queues:95:5) at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/@n8n/n8n-nodes-langchain/dist/nodes/vendors/OpenAi/OpenAi.node.js:16:16) at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:722:19) at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:711:51 at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:1141:20
  • n8n version: latest (1.61.0)
  • Database (default: SQLite): postgres
  • n8n EXECUTIONS_PROCESS setting (default: own, main): main
  • Running n8n via (Docker, npm, callin.io cloud, desktop app): docker
  • Operating system: linux (ubuntu 22)
Posted : 04/10/2024 4:09 pm
Andrea_Santaniello
Update: This issue is specific to the OpenAI block. The AI Agent block does not exhibit this problem.
Posted : 04/10/2024 4:19 pm
ria
 ria
(@ria)
Hi there!
Thanks for posting and welcome to the community!
:tada:
This sounds like a bug! Thanks so much for reporting.
Will post here when it's fixed.
:pray:
Posted : 07/10/2024 11:11 am
Andrea_Santaniello
If you require further details for debugging, please inform me. The problem does not occur when utilizing the AI Agent block, with identical HTTP requests and logic.
Posted : 07/10/2024 2:10 pm
Morriz
(@morriz)
Same here, callin.io seems not able to infer schema and tools call does not include parameters? Where can we control the tools call / function interface between AI Agent and a workflow tool?
Posted : 09/10/2024 2:48 pm
jan
 jan
(@jan)
A new version, callin.io@1.64.0, has been released, incorporating GitHub PR 11201.
Posted : 16/10/2024 11:43 am
Posted : 23/10/2024 11:44 am
