Repeater not functi...
Repeater not functioning as anticipated
Jason_Jakarta
(@jason_jakarta)
Could someone please shed some light on what might be happening here?
Posted : 15/07/2024 6:02 am
Donald_Mitchell
(@donald_mitchell)
Airtable Search Records will return bundles. For searches 1-5, it returns 1 bundle, but for search 6, it will return 2 bundles. This results in a total of 7 Operations on Tools. You didn't show it in the video, but if you expand Operation 6 from that Airtable module, you might see two bundles. I suspect if you change your limit to 1 on the Airtable module, it will be forced to return only one of "session 6", but I don't know which one, so that's probably not reliable.
Also, I don't think you even need to use a repeater at all here. You could just aggregate all the records/sessions into an array, then create an array of the session numbers
[1,2,3,4,5,6,6]
Deduplicate that array to get:
[1,2,3,4,5,6]
Iterate this array (which creates an "i" variable) and for each value of i, use map() and get() to pull the relevant values out of the session array.
Posted : 16/07/2024 2:10 am
Jason_Jakarta
(@jason_jakarta)
Great job! Much appreciated.
Just for your information, I did adjust the limit to 1, and that fulfills my requirements. I was approaching the problem incorrectly, so thank you for the clarification as well.
As a follow-up for future reference, what would be the benefit of replacing the repeater with the array module? Do you believe it offers a more robust solution?
Thanks again.
Posted : 16/07/2024 2:51 am
Donald_Mitchell
(@donald_mitchell)
You would be able to bypass one of the Airtable modules because you'd be utilizing an array. Whenever you can reduce calls to external services, you save a small amount of time and decrease the chance of additional delays or failures should the service be unavailable.
Posted : 16/07/2024 3:45 am
