RuntimeError [404] ...
RuntimeError [404] NOT_FOUND Origin Airtable
Madalena_Clara
(@madalena_clara)
I'm setting up a workflow where I retrieve information from Airtable, generate two texts using Claude, and then update the records in Airtable. However, I'm encountering the following error:
Posted : 23/12/2024 7:39 pm
dilipborad
(@dilipborad)
Can you please share screenshots of any errors and your settings for that updated Airtable record module?
Check these references are from the Airtable community.
→ Specifically, review this response from an Airtable Developer Team member.
Documentation on Airtable API: Airtable Web API.
I hope this helps you.
:+1:
Posted : 24/12/2024 6:04 am
