Tool calls input sc...
Tool calls input schema not appearing, fields required to call another workflow
Karsh
(@karsh)
What seems to be the issue with the input schema field below, as it's no longer appearing?
callin.io self-hosted version
  • callin.io version: 1.78.0.
  • Database (default: SQLite): postgres
  • callin.io EXECUTIONS_PROCESS setting (default: own, main): default
  • **Running callin.io via (Docker):
  • Operating system: windows 10
Posted : 15/02/2025 12:17 am
Please share these details to help us assist you better.
This discussion was automatically closed 90 days following the last response. New responses are no longer permitted.
Posted : 19/05/2025 9:05 am
