How To
2
Posts
2
Users
0
Reactions
356
Views
I have two scenarios in callin.io, each with webhooks.
In my callin.io, I created one tool to enroll into the second scenario in callin.io, but it's enrolling into the first one instead of the second, which is odd.
Posted : 11/01/2025 9:50 am
Hi and welcome to callin.io!
Can you share more details? Are you encountering any errors with your callin.io integration? Have you reviewed the execution trace? Did you perhaps copy and paste a webhook URL and forget to update it?
Posted : 11/01/2025 12:13 pm
